Junkers D-I ...1/33 scale Answer Kit
Discussion in 'Aircraft & Aviation' started by eatcrow2, Mar 26, 2007.
  1. Bowdenja
    Bowdenja Active Member
    It's not the speed............. it's the quality!8)
  2. eatcrow2
    eatcrow2 Member
    skinning
    Your right on the money with those statements...
    Here's one side of the forward fuselage, showing where I've skinned the port side.. Outside piece has to go on first, so the inside piece will hide the tabs.. Also important to try and keep the corrugated detail on the side lined up..
    [​IMG]
  3. eatcrow2
    eatcrow2 Member
    skinning
    [​IMG]
  4. eatcrow2
    eatcrow2 Member
    radiator & motor
    Built the motor and radiator.. tubing for the motor made from wire. Have to have the motor installed before I can add the radiator to the front. Exhaust pipes will be added later on, as they would just be in the way at this point..
    [​IMG]
    [​IMG]
  5. eatcrow2
    eatcrow2 Member
    radiator & motor
    [​IMG]
    [​IMG]
  6. cmdrted
    cmdrted Active Member
    Nice motor, good job so far!
  7. cmdrted
  8. eatcrow2
    eatcrow2 Member
    Have added the motor and radiator. Plus I've added some scrap balsa to the bottom of the fuselage for strength. Will sand to shape, and then add the bottom parts of the hull.
    [​IMG]
  9. eatcrow2
    eatcrow2 Member
    [​IMG]
  10. rlwhitt
    rlwhitt Active Member
    Balsa! Ahhhhhhh!
    Just kidding! As Ted says, Paper on the hoof (love that one).
    Great build!
  11. rlwhitt
    Balsa! Ahhhhhhh!
    Great build!
  12. eatcrow2
    eatcrow2 Member
    Plugging away on this.. Working on the rear of the fuslage, and started making the frames up for the wings.. Definitely will be doing a lot of touching up at some point..
    [​IMG]
    [​IMG]
  13. eatcrow2
    eatcrow2 Member
    [​IMG]
    [​IMG]
  14. cmdrted
    Plugging away just fine!
  15. cmdrted
  16. eatcrow2
    eatcrow2 Member
    tailplane & rudder assembly
    Without real clear diagrams, these were a little bit of a "pain in the rear" to figure out how to make everything work and fit.. Just set in place for now, untill I attach the main wings.
    [​IMG]
  17. eatcrow2
    eatcrow2 Member
    [​IMG]
  18. eatcrow2
    eatcrow2 Member
    main wimgs
    Photos show the making up of the main wings. Had to do a little bit of sanding to the frames to get everything to wrap where it look right to me. They flush up to the fuselage reasonably well on the test fit.
    Laser frames, and the skin of the wing..
    [​IMG]
    Finished wing..
    [​IMG]
    Test fitting to the fuselage...
    [​IMG]
    [​IMG]
  19. eatcrow2
    eatcrow2 Member
    main wimgs
    [​IMG]
    Finished wing..
    [​IMG]
    [​IMG]
    [​IMG]
  20. josve
    josve Active Member
    That is looking really good Peter!!
    I really like the coloring of that aircraft!
