Israeli A4N beta build from papermodels.co.il
Discussion in 'Aircraft & Aviation' started by cmdrted, Mar 25, 2007.
  1. cmdrted
    cmdrted Active Member
    Mostley assembled waiting for the fwd and aft sections to be mated then the hump will be fit up. I left the 301 section loose as I may have to manipulate/fit up that section with the rear rudder section.
  2. cmdrted
    The rudder with flying surface added. The next step is mating up all the fuselage parts, which will have to wait on that 4 letter word looming in the not so distance..... F-ing WORK!
  3. Clashster
    Clashster Member
    Looking beautiful! Are you allowed to use a four letter word like work on this forum??? Thanks for the update!
    Chris
  4. Rick Thomson
    Rick Thomson Member
    As Oscar Wilde said, "Work is the curse of the drinking class."
  5. ml5716111
    ml5716111 Guest
    The openning on top of the hump, is a vent, wether to let cold air in or hot air out, that I never bothered to ask, because those days, there wasn't any equipment installed up there, only some wiring.
    Moshe
  6. cmdrted
    Thanks for the info Moshe, resumed some build, here is the fwd and aft sections fuzed and drying...
  7. cmdrted
    This shot gives some idea of the scooter's size...
  8. cmdrted
    Top view, next on the list will be putting all the previously built details... Coming "soon".
  9. cmdrted
    After the fuzion process, the intakes were next to be installed, the stb went 1st...
  10. cmdrted
    Followed by port...
  11. cmdrted
    I have to say, the fit of these intakes, joined to 2 separate fuselage sections and one irregularly shaped fairing piece had me a little worried. But due to the design process they fit like a proverbial glove! The only itty bitty tiny seam at the bottoms of the intakes have a miniscule gap shown here in SFFMM! And this misfit had to be me! Well designed Dr. Zarkov!
  12. cmdrted
    Overview of the intakes, now on to the hump!
  13. cmdrted
    Canopy comes from the vacuform elv-is, thank you, thank you verra much!
    The next little goodie to afix to the fuselage is the rudder assembly. It has a pretty robust structure, a piece of the former that sticks down thru and aligns the part to thefuse. I cut the slot a little big fore and aft incase it needed a little jiggery pokery to fit just right.
  14. cmdrted
    Starboard overall view.
  15. cmdrted
    One hump or two?
    The next part caused me the most "angst" so far, and I guess from Moshe's instructions and coaching, him too. I cut the formers a little short off the bottoms and dry fit the darn thing @ 5-6 times. It all lines up very nicely...
  16. cmdrted
    There is a very tiny gap up front bottom of the fwd fairing, which I think is just the card thickness, so I can call this a great fit. I did squeeze the centre aft part a tiny bit too much but it still looks good!
  17. barry
    barry Active Member
    Like this one Ted
  18. cmdrted
    Fwd view, so far the very hard parts have come together without much of a hitch. Any misfit must be attributed to me, not the design. There are a few parts that have to have the most attention to detail for a perfect fit, the fwd intakes, the transition between fwd fuselage and aft,, the rudder assembly, and of course the hump. Now on to a little fiddley bit on the fuselage, then the next step called for is the Wing!
  19. cmdrted
    Thanks Barry, this goes together with the perfect fit of a Halinski, it's just my shakey hands that sometimes throw the build off. You did well with your frigate sir, sometime soon I'll have to build up a ship for a change! Here's a closeup of the stb hump to show Carl that I do make some visible mistakes. I make alot of mistakes actually but fortunately they are below the SMFFM scope!
  20. cmdrted
    The next bits were added on as per the instructions, the 1st pic is the underchin sensor, ? IR detector...
