Israeli A4N beta build from papermodels.co.il
Discussion in 'Aircraft & Aviation' started by cmdrted, Mar 25, 2007.
  1. cmdrted
    cmdrted Active Member
    Hi all, it has been a hectic bunch of days at the job. I have a little time so some progress is being made. As the good Doctor pointed out the flare dispensors need to be exterior so I reprinted off some new ones and attached them over the other holes...
  2. cmdrted
    The next segment contains the airbrake housings, these are placed inside the segment...
  3. cmdrted
    Here are all the after fuselage parts ready to be assembled...
  4. cmdrted
    Airbake segment...
  5. cmdrted
    Next couple...
  6. cmdrted
    The exhaust segment with the last segment in place...
  7. cmdrted
    Here is a general view with the forward section approximated. Kinda shows that in 1/32 the scooter is still a fairly large model!
  8. cmdrted
    Carl, take a look at the front segment!
  9. rlwhitt
    rlwhitt Active Member
    Sweet! That's a good looking plane!
  10. rmks2000
    rmks2000 Member
    Really nice! Especially considering this is a beta!
  11. cmdrted
    A little more progress. The model will come as an easy and detailed version. In the easy the control surfaces are one piece and not "posable". The detailed version's rudder is shown with with the actual rudder being built up...
    Internal view...
  12. cmdrted
    External view, the little zig zag piece is the bottom of the rudder and has a small former in it to keep the base the correct shape...
  13. cmdrted
    Surface complete, on to the main body of the beast...
  14. cmdrted
    The main rudder body is made of 4 internal frameing pieces that were built up but "the other" took control of the camera at the time so I built up the skins and connector strips around it, shown here...
  15. cmdrted
    Here are the 2 pieces approximated to show how they will look, now on to the dorsal hump!
  16. rmks2000
    rmks2000 Member
    Nice pix! I like the fact that you have a choice of easy vs. detailed builds, ala Kancho.
  17. cmdrted
    Well a another bit o' progress, the dorsal hump. This assembly starts in the middle, with the 2 bits shown here. I'm not sure what the inner piece on the after of the 2 sections is but it builds up kinda neat and fits perfect. The connector strips even have cutouts for this piece.
  18. cmdrted
    The next sections, growing with the build. Perfect fit! One tip Moshe passed along that holds alot of wisdom, trim the bottoms of the formers a little short, it'll allow the hump to fit better when mounted to the fuselage!
  19. cmdrted
    The after sections ready for assembly...
  20. cmdrted
    The pieces with the hull number were actually supposed to be built with the rudder, but I held off and made them with the hump sections...
