Israeli A4N beta build from papermodels.co.il
Discussion in 'Aircraft & Aviation' started by cmdrted, Mar 25, 2007.
  1. Bowdenja
    Bowdenja Active Member
    They even got the grave diggers with them!
  2. cmdrted
    cmdrted Active Member
    Awright Moriarity, no more negative waves! Here are a couple of so far so good pics, with the slats and stuff installed, topside....
  3. cmdrted
  4. cmdrted
    And the underside. That's it for now, on to the them stabs...
  5. cmdrted
  6. Fishcarver
    Fishcarver Active Member
    Ted: I swear that you will make a "bird builder" out of me yet!!
    Very good work!!
    Jim
  7. Fishcarver
    Very good work!!
    Jim
  8. Amazyah
    Amazyah Senior Member
    That's one beautiful plane cmdr!
    I do believe this will be my next purchase!
    Or one of the next few, anyway!:roll:
    It's just so pleasing to look at!
    Like a woman with all the right curves,... gorgeous!
    They definitely picked the right guy to build this sweetie!
    Very nice build cmdr!
    Russell
  9. Amazyah
    Russell
  10. Texman
    Texman Guest
    Very impressive Ted. One clean build.
    Ray
  11. Texman
    Texman Guest
    Ray
  12. rlwhitt
    rlwhitt Active Member
    Superb building, yet again! Looks like you're almost there!
    Rick
  13. rlwhitt
    Rick
  14. Emil_Zarkov
    Emil_Zarkov Member
    Hi All.
    Ted, please see what I’ve prepared for you.
    This is a Multiple Ejection Rack, mounted on the central pylon.
    Moshe, please choose the armament variant for the beta test building right now.
    I propose 2 variants – one MER attached to central fuselage pylon and two external fuel tanks, or two MERs on the internal wing pylons and one fuel tank on the central pylons. In both cases the wings external pylons should carry Sindwinder IRAA missiles.
    The kit will have also MER/TER option, but I’m afraid that I can’t supply in time the all variants for the beta test assemblage.
    Best++,
    Emil
  15. Emil_Zarkov
    Emil_Zarkov Member
    Hi All.
    Best++,
    Emil
  16. cmdrted
    Emil, I have 6 bombs built up and as Moshe pointed out my lower flaps have been deflected quite a bit and might interfere with the long fuel tanks. So bothe ters and a central fuel tank might be the way to go with this build. But Moshe can have final approval, it is his kit, I'm just the builder!
  17. cmdrted
  18. Emil_Zarkov
    Emil_Zarkov Member
    Ted, if the flaps are 45 degrees or less down, everything will be OK.
    I checked the geometry of the model before extracting the parts.
    Now for the diorama entusiasts...
    Emil
  19. Emil_Zarkov
    Emil_Zarkov Member
    Emil
  20. ml5716111
    ml5716111 Guest
    Emil, I was among the crowd that were watching this competition, shown in this picture. You can see aircraft#306, representing my squadron.
    It was the first and unfortunatly the last I.A.F.s Skyhawk squadrons sport day. It was sometime in 1977, and each squadron competed for:
    soccer, basketball, volleyball and pulling a rope. Also each squadron sent a ground crew and a pilots crew (the pilots competed on the ground just for the fun of it) to compete for the shortest time it takes to prepare a standard flight configuration, consisting of a MER with 6 Mk-62 bombs, 2 fuel tanks and 2 Mk-82's for the outer wing pylons (seen in this picture). My squadron took 1st place in the total score of the ball games, and 2nd place in the "real thing", and that's only because the winning team put some warnning signs around their aircraft, they where from the air base who hosted this event, and got an unfair advantage.
    The judges ignore all other teams' protests :mad: The pilots also competed in the air, doing some bombing and shooting. I do not remember who won this one.
    Ted, until the MER is ready it doesn't matter what you load on the kit.
    The two external fuel tanks, are good. Or 5 MK-82, 1 on each pylon.
    MERs were used on the inner wing pylons only with 5 French 100kg bombs (which aren't in the kit). A possible configuration is 2 fuel tanks, 7 Mk-82 and 1 AA missile.
    There were some experiments with 3 MK-82 on a MER on the inner wing pylons, but we never used it otherwise.
    Moshe
