Infinite justice gundam
Discussion in 'Gallery & Designs' started by Tang.L.B, Jan 31, 2009.
  1. Tang.L.B
    Tang.L.B Member
    1:60 infinite justice gundam
      File size:
      35.4 KB
      408
      File size:
      19.4 KB
      396
      File size:
      27.5 KB
      397
  2. Mousemuffins1
    Mousemuffins1 Member
    Oh, way cool. it will be pink, Right?
  3. Tang.L.B
    Tang.L.B Member
    and SD one
      File size:
      130 KB
      File size:
      101.5 KB
      388
      File size:
      124.8 KB
      381
  4. Paragon
    Paragon Active Member
    Now there's a good looking Gundam. How did you churn out that SD so fast?
  5. Tang.L.B
    Tang.L.B Member
    go on
      File size:
      54.2 KB
      14
      File size:
      42.6 KB
      9
      File size:
      22.8 KB
      339
  6. ltla9000311
    ltla9000311 Member
    Tang.L.B, very nice work! Do you post over at PPX?
  7. Tang.L.B
    Tang.L.B Member
    yes!
  8. Mousemuffins1
    I want one. Will this be available as a kit?
  9. ltla9000311
    ltla9000311 Member
    I thought I recognized your bust from there too! Very nice work so far!:thumb: Which program are you using for the designing of this model?
  10. Mousemuffins1
    Is there a link to this PPX club? I'm not having much luck with my searches.
  11. Tang.L.B
    Tang.L.B Member
  12. Tang.L.B
    Tang.L.B Member
    go on
  13. ltla9000311
    ltla9000311 Member
    Tang.L.B are you designing this in scale, and then making it SD? If you are, will the standard version be available too?
  14. Tang.L.B
    Tang.L.B Member
  15. imdead
    imdead New Member
    do u also use finalpaper.net? cause i saw ur 1:60 Ifinite Justice on there just with complete body and no backpack
  16. Tang.L.B
    Tang.L.B Member
    regular scale infinity justice gundam in process, now adjusting the head
      File size:
      34.3 KB
      13
      File size:
      30.2 KB
      12
      File size:
      18.1 KB
      13
  17. Tang.L.B
    Tang.L.B Member
    go on
      File size:
      9.3 KB
      224
      File size:
      14.7 KB
      222
  18. Tang.L.B
    Tang.L.B Member
    a friend of mine is going to build the model
      File size:
      87.2 KB
      12
      File size:
      193 KB
      9
      File size:
      186 KB
      12
      File size:
      28.4 KB
      183
      File size:
      30.8 KB
      185
  19. Tang.L.B
    Tang.L.B Member
    Let's go on
      File size:
      119 KB
      154
      File size:
      148 KB
      154
      File size:
      167.3 KB
      10
      File size:
      130.7 KB
      10
      File size:
      126.8 KB
      152
      File size:
      151 KB
      14
  20. Soaring
    Soaring Middle School Student
    I gotta ask Tang, how do you do it? The textures, the design? My gosh man, it looks brilliant!
