Imcold X-Wing - discussion/building thread (http://xwingpm.wz.cz/)
9,549
Good to point these things out, is one an end piece, or are they both the same part, just mislabeled?
starbuck
898
1,825
93
Austria - Carinthia
Next parts identified and ready for processing. Also here some additional details I am gonna use.
.....and cut and glued to additional layers to get the correct size.
bigpetr
Designer/Master Modeler
Jan 27, 2016
922
1,461
Czech Republic
Something I forgot. There is a small error in the description file as can be seen in the attached screenshot.
Thank you for pointing this out, Starbuck.
To sum it up - parts are mislabeled in the instruction drawing. They are corectly designed and labeled in the template itself.
Reactions: zathros
starbuck
898
1,825
93
Austria - Carinthia
Next parts put together.
Tip:Before gluing, check that these parts fit to the wings. I first glued inside and then they did not fill the white parts on the wings.
Next parts cut out. I do not habe an exact idea how and where to place them. I hope my plastic model will show me the way.
Dagger
215
456
40
Very good work! I hope you find the place of those pieces, the thread of Bigpert can serve as a guide.
9,549
Wow!! Awesome!! :))
starbuck
898
1,825
93
Austria - Carinthia
Additonal question regarding bigpetrs part 6.
Why double? Optional which to use as they have different colours?
I tried all possible combinations and decided to take the brighter parts, as they fit better to the rest of the wing.
I glued them on an additional layer of paper to make them pop-up.
Pictures to follow.
Reactions: lyter1958
starbuck
898
1,825
93
Austria - Carinthia
some posts before:
@ Additonal question regarding bigpetrs part 6.
The answer is: parts are needed on both sides of the wing. :hammerhead:I forgot to place them on the inner side - you can also see on the picture.
Meantime corrected;-)
9,549
Excellent workmanship! thumbsup
starbuck
898
1,825
93
Austria - Carinthia
Based on the small parts I decided to make a test to be sure to avoid mistakes. Most parts are on thin paper, only few are made of thicker paper, which was also one of the reasons for a testbuild. Never worked with thin paper before. (Beside adding an additional layer to a part.)
Here first picture.
