Hubble Space Telescope Build
Discussion in 'Space & Aeronautics' started by CardStalker, Mar 1, 2008.
  1. CardStalker
    CardStalker Member
    Part 9 & 11
    Time to seal up the bottom. The corner tabs get folded down and tucked in behind the corners of part 1. Then Part 9 is cut out and glued to the bottom of part 1. Part 11 is cut out and overlaid onto part 9.
  2. CardStalker
    CardStalker Member
    Hello all. Got a little behind on this project, I have more done and will post soon. However, it might get real slow form here on in, and I might not make the date. I just last week tore the rotator cuff on my left shoulder pretty bad and my range of movement in that arm is greatly reduced. Getting a MRI on Friday to see how much damage and what surgery I might need. But if I have my way, I'll find some way of completing this.
  3. George B
    George B Senior Member
    Ouch.....hope you make a speedy recovery.
  4. CardStalker
    CardStalker Member
    Thank you George, my best to you.
  5. CardStalker
    CardStalker Member
    Parts 13/14/15/16
    Here are parts 13/14/15/16.
  6. CardStalker
    CardStalker Member
    Part 13
    Part 13 gets cut and folded into a box.
  7. CardStalker
    CardStalker Member
    Part 13 location
    Part 13 then gets glued to the bottom of part 1 in the center.
  8. CardStalker
    CardStalker Member
    Part 14
    Part 14 gets cut out and scored at the sides.
  9. CardStalker
    CardStalker Member
    Part 14 location
    Part 14 then gets glued onto part 13 and the arms get glued to part1. Note the location and position.
  10. CardStalker
    CardStalker Member
    Parts 15/16
    Parts 15/16 cut out.
  11. CardStalker
    CardStalker Member
    Parts 15/16 together
    Parts 15/16 get glued back to back, with colored ends opposite each other.
  12. CardStalker
    CardStalker Member
    Parts 15/16 location
    Parts 15/16 get glued to the top of part 1, with part 16 facing out.
  13. CardStalker
    CardStalker Member
    Next are the Radial Instrument
    Radial Instrument part 17/18/19/20.
  14. CardStalker
    CardStalker Member
    assembly 17/18/19/20
    Parts are cut and folded. Parts 17/18/19 have a curved bottom. Roll the bottom before assembly.
  15. CardStalker
    CardStalker Member
    assembly
    I have to let everyone know at this point, I'm building two of these at the same time. One to test build and one for this contest. This way I can find out the best way to build this. The test build will go with my daughter to be given to our local High School. Parts 17/18/19,20, I found are best built by gluing the top part to the sides first. This allows for better alignment to make them more square.
  16. CardStalker
    CardStalker Member
    Closing
    Finish with the bottom to complete assembly.
  17. CardStalker
    CardStalker Member
    Parts 23/24
    Here are parts 23/24.
  18. CardStalker
    CardStalker Member
    Location
    Glue parts 17/18/19/20 to the location points on part 23.
  19. CardStalker
    CardStalker Member
    Parts 21/22
    Parts 21/22 are overlays to be applied to parts 17/18/19. The long straight parts are applied to the tops of 17/18/19 and the small squares are applied to the ends.
  20. CardStalker
    CardStalker Member
    finish
    Finaly part 24 is glued to top of the assembly.
