How to Make Rivet Lines in Photoshop
Discussion in 'Gallery & Designs' started by Gil, Aug 10, 2005.
  1. Gil
    Gil Active Member
    Weld Lines
    For Armour...,
    Gil
  2. Gil
    Gil Active Member
    Weld Lines
    For Armour...,
    Gil
  3. RyanShort1
    RyanShort1 Member
    FYI GIMP also has a feature where you can create your own brushes...
    Script-Fu - to
    Selection - to
    Brush
    I'm also thinking I've seen a way you can make a dashed or other type of line that might be useful for things.
    Ryan
  4. RyanShort1
    RyanShort1 Member
    Script-Fu - to
    Selection - to
    Brush
    Ryan
  5. Gil
    Gil Active Member
    Ryan,
    The combinations of the paint brush tool in most of all the "paint" packages are capable of performing a similar action. "Pinked" and stitched seams come to mind for fabric covered aircraft and are easily done with this technique just to start and endless list of possible applications. One other thing it also works on geometic shapes too...,
    Gil
  6. Gil
    Gil Active Member
    Ryan,
    Gil
  7. NYC Irish
    NYC Irish Member
    :D
    Gil Im so greatfull ...
    Thanks John John
  8. NYC Irish
    NYC Irish Member
    :D
    Thanks John John
  9. tausugAir
    tausugAir Member
    Gil....
    I guess I missed on this one but I would appreciate very much if this can be reposted...Many, many THANKS....
    Muhammad
  10. Gil
    Gil Active Member
    Sorry, but I didn't save the original files. I'll have to do it all over again which will take time. It's simple enough though. Draw a rivet. Scale it to an appropriate size. Set it as a new Brush. Fiddle with the period of the brush to obtain rivet spacing. Select rivet brush and draw lines with it using the Shift key in conjuction with the left mouse button. Note that any repeating "brush" can be created with this method.
    -Gil
  11. tausugAir
    tausugAir Member
    Gil :
    Thanks so much for the guide... I will give it a try . Regards,
    Muhammad
