"How to Build Large Scale Dioramas"
Discussion in 'Dioramas & Displays' started by JohnReid, Jul 7, 2007.
  1. JohnReid
    JohnReid Active Member
    Amati Bleriot
    Does anyone have an Amati 1/10th scale Bleriot model kit for sale? I am looking to build a simple diorama using a French military version.I believe it was the first aircraft sold to the French army and the first to serve in military operations.
    Cheers! John.
  2. JohnReid
    I guess I should explain this sudden Bleriot diorama thing.I will be doing this short build after the Jenny but just before the major RAF commission, which I anticipate will take years to build.
    The reason I took this on is because this will be my contribution to help promote the 100th anniversary of the Ist air show in Canada in which the Bleriot took part. .It was held in Montreal in 1910 from a field just down the street from where I live. They are actually building a full scale replica and plan to fly it from near where this airshow was held all those years ago.
  3. JohnReid
    Bleriot XI
    Is there a cardmodel made of this airplane? Thanks!
    Cheers. John.
  4. dansls1
    dansls1 Member
  5. JohnReid
    Bleriot XI being built in Montreal.
    Bleriot
  6. JohnReid
    Thanks dansis1!
    Cheers! John.
  7. JohnReid
  8. Amazyah
    Amazyah Senior Member
    Great article! I could envision the whole thing in my mind as I read it!
    It must have been quite a thrill to live during that time period when the actual flight of humans was first discovered!
    To see a plane for the first time! What an exciting moment that must have been!
    Thanks for sharing that John! Where did you find it?
    Russell
  9. JohnReid
  10. JohnReid
    Hi Russell!It was sent to me by a group that is now getting together to help promote the 100th anniversary of this event which will be held in 2010.They plan to fly the Bleriot being build now on the west island of Montreal ,as part of the events that are only now beginning to be planned .Will keep you informed!
    Cheers! John.
  11. Amazyah
    Thanks John! Your dioramas sure bring that era to life as well and it is inspirational to see your work!
    The picture above is no exception!
    Russell
  12. JohnReid
  13. JohnReid
    Dioramas as camera backdrops.
    The last few pics give you a good idea of how dioramas can be used as backdrops for pictures.Just by rearranging your subject matter endless story lines are possible.It is a great tool for learning lighting,camera angles,etc...
    If you make it so that it could be taken apart and stored between camera sessions ,that would save on the storage problems when dealing in the larger scales.Models and figures could be re-worked and repainted between camera sessions at minimum cost and used in your photographic dioramas .Videos could be used to do your own walkarounds using your own models.Jeez guys,why not give dioramas a go ,the possibilities are endless!!!!! And besides in the end the pics may be the only record of your work that survives.
    __________________
    It has been said that the difference between a "pilot" and an "aviator" is that a pilot is a technician,and an aviator is an artist in love with flight.
    JohnReid (Aviator)
  14. JohnReid
  15. JohnReid
  16. JohnReid
    After spending a lot of time fooling around trying to modify the spark plugs ,I think that they are still way out of scale and just boo ugh ,so I am going to remove the ends and just make plugs (tampons) out of them.
    I kind of like the brass valve lifters and may just leave them like they are rather than painting them silver-grey.(a little artistic license)
  17. JohnReid
  18. JohnReid
    OK ,now that looks better! In fact it looks more like an engine that has been inhibited for transport ,using hex bolts to replace the spark plugs.
    _
  19. Fishcarver
    Fishcarver Active Member
    WOW!
    And those figures are just great!!
    Jim
  20. JohnReid
    How Rotary engines work!
    for a nice animated look at how a Rotary Engine (Gnome) works,check out
    Animated Engines, Gnome
