"How to Build Large Scale Dioramas"
Discussion in 'Dioramas & Displays' started by JohnReid, Jul 7, 2007.
  1. JohnReid
    JohnReid Active Member
  2. JohnReid
    Finishing the old fuse!
    Before installing the R/H sidewall it will be necessary to finish the basketcase fuselage.I have removed it for this purpose and must now decide how I want to secure it down to the hangar floor.The main thing going on here is the mechanic is removing the instruments from the panel.In reality the panel probably would have been removed in one piece a long time ago ,but I had I have him doing something and I had a lot of nice 1/16th flight instruments that I thought would be an interesting detail.
    To secure the tail I decided to attached it to a old plastic wheel I had hanging around from another build.I painted it metal and weathered it and attached it to the tail post with a chain.
    __________________
    It has been said that the difference between a "pilot" and an "aviator" is that a pilot is a technician,and an aviator is an artist in love with flight.
    JohnReid (Aviator)
  3. JohnReid
  4. JohnReid
  5. JohnReid
  6. JohnReid
    Winter project.
    The last major build of this diorama will be the Camel/Ford truck assembly.I am really looking forward to getting back to building airplanes again.The car in the pic is a diecast and used here for reference only.(it eventually will be weathered and parked outside the office).It will be nice to finish this diorama on a high note with a aircraft/truck build.I really want to take my time with this as it will be the best closeup view of any airplane in the composition.I would also like to improve my figure painting to a level that I have seen elsewhere,as my next diorama "The Backyard Flier" will not have the advantage of indoor stage type lighting.The Flier will also require some totally scratchbuilt figures which is an area of this artform that I have yet to explore.I have always much admired the guys who can do small scale figures and actually make them look like some historical figure.It would be a wonderful place to finish up this modeling adventure of mine.
    __________________
    JohnReid (Aviator)
  7. JohnReid
  8. JohnReid
  9. JohnReid
    I appreciate the wonderful responses that I get from posting my work.While it is great for my ego,it really isn't my primary reason for doing it .I believe that dioramas that tell a story are really "little works of art" and I think someday they will probably be better recognized for what they really are,3D art..Think of Shep Paine or Ken Hamilton's work, are their dioramas not like little one frame movies?The great thing about good dioramas is that they demand a certain level of involvement of the viewers imagination.The image of a well done diorama will stick in the viewers mind, and in the case of other future artists ,may well have some inspirational value.As artists, in the end that is all we can hope for,to be a part of this never ending flow of creativity.I know in my own case Shep Paines work had enormous influence on me long before I started doing dioramas.I bought his book years before and would pick it up and read it from time to time.
    I was very involved with decorative bird carving at the time but those images stuck with me.When I was looking around for something new to do,it finally struck me.Why not combine my lifetime passion of being in and around aircraft with my interest in dioramas as art?
    I never met Shep Paine but he had enormous influence on me .When I heard that he was tired and wanting others to run with the diorama ball a bit ,I took up the challenge ,as I am sure many others have done.I am in no way comparing my work to his but it is different and I hope it contributes in some small way to what I believe is a growing form of artistic expression.
    __________________
    JohnReid (Aviator)
  10. JohnReid
  11. Millenniumfalsehood
    You're work is positively inspiring! You're right: dioramas are 3D art, and should tell a story. I've had one in mind to build for myself: a sniper is perched at the top of a hill looking through binoculars, searching for the target to confirm that he's dead. Unbeknownst to him, the pilot he tried to gun down was only hit in the leg and is crawling up the side of the hill,trying to get a shot at him.
  12. JohnReid
    Looking at this picture now,I probably could have got away without using all those aircraft parts on the floor at the bottom R/H corner.Actually they are mostly made up of parts that I never used on the Neiuport aircraft in my 2nd diorama.Gizmology I think it is called!Those rolls of coiled wire hanging down from Jenny's fuselage were originally to be attached to the flying controls but I have since decided they look good as they are besides at this stage of a real aircraft build rigging the controls would be one of the last things to be done.This Jenny depicts an airplane being test fit before breakdown for the final fabric covering.
    I see I forgot the little piece of broken rib that should be on the floor next to the wheelbarrow.Believe it or not but a small touch like this will draw a viewers eye every time.Gilding the lily so to speak,much like a painter of portraits will add a small sparkle to the eye.My first experience with this phenomenon was when I accidentally knocked over some nuts and bolts off of a work table that were sitting in the Neiuport diorama .It became the object of so much attention that I just left it like that.
    Today I will finally glue down the old Jenny's spare wings to the racks which will pretty much finish off the L/H side wall.
  13. JohnReid
  14. JohnReid
  15. JohnReid
    Movin along!
    Today was a major milestone in the evolution of this diorama.All the hangar walls are finished and everything is glued down to the hangar floor except for some minor work on the Jenny tie downs and the fighter pilot group.
    I think that I will put on the rafters and hook up the lighting and then work on finishing the modules exteriors where necessary.
    All the exterior landscaping panels top screws will have to be removed and re-screwed from the bottom and the landscaping can then be finished.The one panel that will serve as the base for the Camel/Ford truck will be finished as a unit and will be installed last.Anyway that is the plan for now.
    __________________
    JohnReid (Aviator)
  16. JohnReid
  17. JohnReid
  18. JohnReid
  19. JohnReid
    Ken,Jim and I all started building large scale kits around the same time.I started with the Albatros and Ken and Jim with the Nieuport.Ken went on to build the most magnificent scratchbuilt aircraft that I have ever seen . Jim did a super job of modifying this kit but he is also a great scratchbuilder as well.
    If you would like to see more of their work go to:
    World War I Modeling Page then "Galleries"
    Enjoy!
    Cheers! John.
  20. JohnReid
