How to build a control Panel
Discussion in 'Tips & Tricks' started by fifer, Jan 24, 2013.
  1. fifer
    fifer Active Member
  2. Zathros
    Zathros Guest
    Mike, I embedded the video for you, it is easy to do. Just to go the advanced mode, press the YOU/TUBE button and copy and paste, this case, the numbers HdjpUyc9w6s in between the YouTube brackets, and the video will be embedded. It's easy, you do it once and you'll see, great video!! The sticky back Velcro is such a good idea!!
    I noticed you are not having trouble cracking the plexiglass. Are the drill bits for wood or for metal (as far as how they are sharpened?), Also, this is not Lexan is it? :)
  3. fifer
    fifer Active Member
    It is a metal bit and no it is not Lexan.
    Thanks , Mike
  4. Zathros
    Zathros Guest
    I thought they might be. When I was a machinist, the standard angle for metal was 117 degrees. This makes for a shallow whole and less "grabbing", which is probably why you have such nice holes. A very nice tutorial. Thank You! :)
  5. fifer
    fifer Active Member
    Thanks , I have had good luck and no broken Plexi in about 10 panels I have made.
    Thanks , Mike
