Home made bolt heads.
Discussion in 'Tips & Tricks' started by Sawdust, Jan 16, 2009.
  1. Sawdust
    Sawdust Member
    For you HO scalers I take the metal head type straight pins & chuck them in my dremel tool. I then spin this pin head on top of a metal file until I get the right diameter, of coarse looking thru my magnifiers. I then round over the newly shaped bolt head slightly to give it that carriage bolt head look for those that are looking tooooo close but it will be there. I also place many of these on a piece of foam board & paint them. I then cut them off leaving a small shank to push into a pre drilled hole. Some of you larger scaled modelers could probably use these as is without grinding them down. Jim
    _________________________________________________________________
    YOU CAN BE ON THE RIGHT TRACK, BUT IF YOUR STANDING STILL YOU MAY GET RAN OVER.
