Here Are Pictures Of My Layout
Discussion in 'N / Z Scale Model Trains' started by RAY METIVIER, Jul 17, 2002.
  1. RAY METIVIER
    RAY METIVIER Member
    Hi Mike ane everyone
    My computer is not back yet, should be back next week, the primary hard drive went bad. Good thing I had everything backed on the secondary hard drive.
    I barrowed this comp. to send this message. Hope to be on line by next weekend with new pictures.
    Thanks.
  2. SD90
    SD90 Active Member
  3. RAY METIVIER
    RAY METIVIER Member
    HI, I'm back.
    More pictures.
  4. RAY METIVIER
    RAY METIVIER Member
    and
  5. RAY METIVIER
    RAY METIVIER Member
    I apologize for the poor quality of the pictures. The origional photos look great. Something happened when I reduced them to post.
  6. SmolderZ
    SmolderZ Member
    Still adding stuff, amazing :)
    I love the trailer park!, very realistic
    Did something go wrong when you resized em?, I really want to see that last picture in it's full original size :)
  7. Clerk
    Clerk Active Member
    WOW!! Ray. Doesn't get a little tedious putting on all that detail? I envy you being able to work in all that detail.
  8. Gavin Miller
    Gavin Miller Member
    Ray,
    Truly inspirational as ever!!
    Shame about the file size requirements here. Sure takes out a lot of pixels when you have to reduce the quality and size to fit.
    Gavin Miller
  9. Matthyro
    Matthyro Will always be re-membered
    Wow even a windfarm Ray. Do the blades spin?
    Great modelling friend.
    Regarding picture size Ray, your pictures should be bigger.
    The size limit is 640 pixels by 480 pixels. Now if resolution is too high save them as a jpeg file using a 50 percent level. This doesn't cause pictures to be of less quality. Your pictures then should be bigger.
  10. RAY METIVIER
    RAY METIVIER Member
    Dave, I will e-mail them as soon as I figure out how.
    Robin.
    the wind generators turn using a small Swiss made gearmotor. they can rotate from 3 to 60 rpm.
    I worked on the pictures, see if this looks better.
  11. SmolderZ
    SmolderZ Member
    Great picture Ray!, I can look at it for hours! :D
  12. Matthyro
    That's a much better picture Ray.
    Now I am curious about those wind generators. Did you scratchbuild them or did you buy them, and if so from whom. Thanks
  13. RAY METIVIER
    RAY METIVIER Member
    Robin
    They are a walthers kit in HO. They measure about 200 scale feet in "N" scale. My research showes the larger ones out west are 211 ft. I had a problem finding motors small and slow enough to fit in the origional housing. Had to settle for a larger gearmotor and kitbash a new housing, which are not much larger then actual housings. The gearmotors are about the same price as a Atlas replacement motor if bought in quanity. The gearmotors are 12 v.DC. I run them at about 6vDC for about 30 RPM.
  14. RAY METIVIER
    RAY METIVIER Member
    Another test picture.
  15. Cinnibar
    Cinnibar Member
    Your Layout
    Ray,
    Absolutely Fantastic!!!!!!!!! Your hobby dealer has to be the happiest guy in Ohio! Love your "Santa Fe Clouds"! :eek:
  16. Matthyro
    The trailer park photo looks great Ray. A lot more details visible.
  17. RAY METIVIER
    RAY METIVIER Member
    More pictures
  18. RAY METIVIER
    RAY METIVIER Member
    and
  19. RAY METIVIER
    RAY METIVIER Member
    last
  20. SmolderZ
    SmolderZ Member
    Thank you Ray!, it looks to good to be true! :cool:
    Question, where did you get those trees from?, I wonder if they make em in Z-scale ;)
