Hanriot HD-1 from Modelik
Discussion in 'Kit Reviews' started by Dragos, Jun 15, 2008.
  1. Dragos
    Dragos Active Member
    1. Model Subject : Hanriot HD-1
    2. Scale : 1:33
    3. Publisher and model number : Modelik 14/2004
    4. Designer if available : Gabriel Panait & Janusz OleĊ›
    The model looks simple to build ,it has 2 sheets with pieces, but it's not quite like this because the instructions aren't very clear. Here is the building thread : http://forum.zealot.com/t158401/
    The model can be build in couple of hours and in the end it is kinda fragile because it doesn't have a internal structure, but it's a beautiful airplane. The most dificult part has been the insertion of the wires because as I've said it is fragile.
  2. foreigndevil
    foreigndevil New Member
    Nice job. Is the grass printed as mentioned in the other thread?
  3. Dragos
    Yes , the grass is printed.
  4. cdavenport
    cdavenport Member
    Printed grass
    Where can I get the printed grass? I have a simple technique for making it 3D.
  5. Dragos
  6. cdavenport
    cdavenport Member
    Thank you, Dragos!
  7. foreigndevil
    Thanks! That's a great site!:thumb:
  8. cdavenport
    cdavenport Member
    Here's a little trick for you all. If you want to make the grass look 3D, brush on a coat of Elmer's school glue (white PVA, which dries clear), a small section at a time. Then sprinkle some finely ground herbs on top. Not only does it smell great, but when you photograph the model, it looks as if it is parked in grass!
