Hako Halo Series #2: CCS-Class Cruiser, the Truth and Reconciliation
Discussion in 'Science Fiction & Fantasy' started by RocketmanTan, May 14, 2010.
  1. RocketmanTan
    RocketmanTan Well-Known Member
    I've recently started my Hako Halo Series, which is basically, Halo ships in Hako form. I just posted the Pillar of Autumn (the Hako version) in the downloads section, and I've already started working on the next release, a covenant CCS-class cruiser, namely, the Truth and Reconciliation. The model will be in the same scale as the Pillar of Autumn, and hopefully, more detailed.
    More to come as the design progresses.
  2. RocketmanTan
    Well, the prototype pattern is complete... I'll start test-building soon...
  3. RocketmanTan
    My test build is finally complete!! And, although it's not the best model I've designed, it definitely has the least amount of bugs in any build I've done!. Pictures soon to come.
  4. RocketmanTan
    Pictures!!!
    Well, here are pictures of the model. You guys tell me if I should remove the lines on the hull. And yes, I am STILL using the damned webcam...
  5. Paragon
    Paragon Active Member
    Not too bad looking. I personally would remove the lines.
  6. RocketmanTan
    Yeah, I thought so. It's gonna be a pain in the @ss, though...
  7. dkaniel
    dkaniel Member
    Why not release a version with the lines, some of us modelers don't mind it, and then later when you are able release another version without lines.
  8. RocketmanTan
    Nah, I probably won't, it'll confuse a lot of people...
  9. RocketmanTan
