GPM U-60 Blackhawk at 1-72 scale
Discussion in 'Aircraft & Aviation' started by airbob, Apr 15, 2007.
  1. airbob
    airbob Member
    This is the progress I have made continuing from the thread "guess what I'm making"...to make the thread topic a little clearer....I am working on the engine housing and you can see it and the rear frame sitting upon the fuselage....the macro lens shows it all!:oops: :-o
  2. airbob
    airbob Member
  3. airbob
    airbob Member
    U-60 Engine housing finished
    I've pretty much finished the engine housing on top of the U-60....maybe I'll finish this before New Years!:twisted:
  4. Amazyah
    Amazyah Senior Member
    Slow and steady wins the race!
    Looking great, Bob!
    Russell
  5. barry
    barry Active Member
    chopper
    That looks brilliant Bob
  6. Krzychu74
    Krzychu74 Member
    Hello!
    Looks great! I will be waiting for more further under construction progress.
    Best regards.
    Krzychu74
  7. Cybermac
    Cybermac Member
    Great job Airbob!
  8. cmdrted
    cmdrted Active Member
    Great job, how is the fit so far, did you have to do any/alot of trimming?
  9. airbob
    airbob Member
    The fit was overall good....I made a mistake on not making the framework out of
    thicker cardstock...and got some strange panel lines as the build went on....and I had to adjust some in the fit of the outer panels especially along the bottom and the final 2 tail sections....the color was completly redone....the original was way too brown for my taste....I think that this will be my only build of this creature...the complexity of the multiple curved surfaces is mind-bodgeling....but it has been most challenging!....but not something that I will repeat!!!:razz: :razz: :razz:
  10. airbob
    airbob Member
    U-60 Blackhawk...continuing fuselage...
    This is the work that I did on this "tadpole" over the weekend...it's got flaws a many...but I shall not tarry...and shall complete this...eventually!!!:roll:
  11. eagleone
    eagleone Member
    Blackhawk
    What is the website that you got it from?
  12. rickstef
    rickstef Guest
    you can get the fullsize pre printed kit from www.papermodelstore.com
    should be able to get the model for 10 or 15 bucks
    and as always keep an eye on ebay
    Rick
