Free Model #3 - White Knight by JM
Discussion in 'Aircraft & Aviation' started by Lex, Feb 14, 2008.
  1. Lex
    Lex Dollmaker
    Now it's my entry into the free model competition......... The White Knight by Jan Muller, --most people probably know this famous model already ^^
    JM precision cardmodels - Startseite
    *Site down... The model is available from Wayback
    http://web.archive.org/web/20050206060036/www.cardmodels.de/Download/White_Knight_Contest_pwd.pdf
    Password is kartonbau.de
    And yea, making a start, last night I managed to finish the central fuselage. The camera's battery gave way during the build, so I was only able to take some final shots. The model was designed by Rhino so great fit, but I did manage to screw up a few formers which fortunately was not visible once they're stuck inside the fuselage... :D More pics follow as I move along~~
    P: I know from the start I had no chance of winning this one at all, but everything is for fun isn't it?sign1
  2. Soaring
    Soaring Guest
    Whoa.....That's epic!
  3. Toddlea
    Toddlea Member
    Everyone has a chance of winning. Good Luck to you.
  4. KCStephens
    KCStephens Member
    Lex,
    Very nice so far. Look forward to seeing more :thumb:
  5. lriera
    lriera Member
    I don't know about it, but I am going to love this model and your build. Thanks for sharing.
  6. Mark_1984
    Mark_1984 Guest
    Nice start Lex. Looking forward to seeing how it comes out.
  7. Lex
    Lex Dollmaker
    Sorry no progress recently... was having teenager's blue for the entire last week, hopefully I'm back on track by Monday ^^
  8. Lex
    Lex Dollmaker
    Back with some progress at last... Today is the wings, the first challenge so far. The previous time I've built this aircraft, the wing ribs showed up badly... (actually, as with every other aircraft I built up till now >_<) So I was determined for a change! This time all the wing support was covered with a double-layer stripe of paper, to the effect of:
    1, The wing doesn't bend and hug around the rib after getting soaked by glue, since now with the stripes the load can be distributed more evenly.
    2, The bending and torsional strength of the wings are increased, as dictated by beam theory.
    --And it worked!! Perfectly straight wings without a visible bulge! Once again science saves the day!! Moving on to the outboard wings tomorrow...
    (--The Comet exclusive scale cube also makes a first appearance ^^)
  9. Gainer
    Gainer Member
    I built one once...it's a pretty nice model, especially considering it is free, now you just needa spaceship one to go along with it
    Not to be rude, but actually, it is Ralph Curell's model.
  10. Lex
    Lex Dollmaker
    Gainer: The SS1 is from Ralph Currell, and it was Jan Muller who designed this WK to go with that ^^
  11. Lex
    Lex Dollmaker
    Some progress
    Finished the entire wing section yesterday, absolutely great fit!:thumb: Only problem is I used wrong thickness for the formers resulting in a difference in length between the spar and the wing. --But that didn't affect the shape since the wing is pretty much the same cross-section all the way across.
    Next is the side fuselages, this is the first time I used a "batch" process to cut out the parts, whereas before I always tried to cut one part, glue it together, and the cut another part, which proved to be slow... That's one lesson learned sign1
  12. Lex
    Lex Dollmaker
    The side fuselage fitted together without a hitch, a test-fit of the joint with the wing was also satisfactory ^^ Moving on to the other fuselage now...
  13. Mark_1984
    Mark_1984 Guest
    The wings came out well Lex. It's turning into a nice, and large model
  14. Lex
    Lex Dollmaker
    Thanks Mark! I tried to make everything in pairs so they are as symmetric as possible, and it came out well. Today I finished the side fuselages and attached them onto the wings, the two sides were attached at the same time so that they are level with respect to the other. I also made the vertical tailfin, which proved to be trickier than expected... More progress follow
  15. Lex
    Lex Dollmaker
    ...and just a photo on the wingroot
  16. BARX2
    BARX2 Member
    Really great work! :)
  17. Lex
    Lex Dollmaker
    Today's topic... Engine pods. The parts which normally causes pain and suffering on other models now seems to be very easy to build, thanks to the way Jan Muller unfolded them sign1 The result was very nice. (...to the extent that I wanted to take a bite at the little pods...:oops:)
  18. Lex
    Lex Dollmaker
    ...Mounted onto the fuselage, now the jet is almost complete, only the landing gears left!!:mrgreen: One slight problem though... the thing is TAIL-HEAVY!!:eek: I better think up something before the plane topples over on the tarmac >_<
  19. cgutzmer
    cgutzmer Guest
    You need a sensor array in the nose :)
    Thats a great build you have going there. nice straight lines! It would be easy to spot a twist with those pontoon thingies :)
  20. Lex
    Lex Dollmaker
    Thanks for the tips guys! I was intending to stuff tin solder wire into the front landing gear assembly, but there wasn't enough volume for the weight. So... basically, I was left with the only option of building an extremely nose-heavy SS1 and strap it below as n810 kindly suggested... That'll have to wait till my printer gets back to life, for the time being, I'm planning on hanging the model from the ceiling ^O^
