Fokker D-VII... 1/33
Discussion in 'Aircraft & Aviation' started by eatcrow2, Apr 24, 2007.
Thread Status:
  1. eatcrow2
    eatcrow2 Member
    Fokker D-VII from new company "Kartonowa Kolekcja". Designed by Pawel Mistewicz..
    [​IMG]
    Have decided to slowly start on this, so that I'll take my time and do some of the extra detailing I want to do..
    You can see where I've glued the parts on 1mm stock. Cut out and glued up one side of the fuselage. In the cockpit area where you will see the tube framing, I decided to use plastic rod painted aluminum and glued over the printed frames for more of a 3-D look..
    [​IMG]
    [​IMG]
  2. eatcrow2
    eatcrow2 Member
    [​IMG]
    [​IMG]
    [​IMG]
  3. DrBill
    DrBill Member
    Peter: Wonderful choice! I just got a copy in the mail yesterday, and have been drooling over it ever since. Got to get the current build out of the way first, but I'll be following this thread very closely for guidance. Thanks for leading the way!
    As far as I can tell, this is the only kit so far from Kartonowa Kolekcia. Is that correct? If so, I'm looking forward to seeing more.
  4. DrBill
    DrBill Member
  5. eatcrow2
    eatcrow2 Member
    Hi Bill...
    When I get irked at my current build (Junkers), I figure I can always switch to this for a bit..;-) Plus I think I would spend more time on small details, if I'm not in such a rush to close everything up..
    Yes this is his first release.. I think his plans are to upgrade some of the designs that he did for Maly Models.. If they are as nice as the D-VII, I'll be getting more.
  6. eatcrow2
    eatcrow2 Member
    Hi Bill...
  7. Jim Krauzlis
    Jim Krauzlis Active Member
    Great looking start, Peter!
    Where did you find this model? I've been looking for a good model of the DVII for a while, and this seems to have a lot of wonderful detail.
    I know I will enjoy watching this build!
    Cheers!
    Jim
  8. Jim Krauzlis
    Cheers!
    Jim
  9. DrBill
    DrBill Member
    Jim: Not sure where Peter got his, but mine came from Paper Model Store in Chicago -- good prices, excellent service in my experience.
    I'll have to go back to my collection (limited) of Maly models to see what else Pawel M. has designed. What I like is the very clean design, the use of detail where appropriate (not hidden), and the opportunity for extra detailing. The GPM Fokker E.II (which also came with the order) is incredibly detailed -- 17 parts to make the propeller and hub alone, and a gazillion wing ribs with no laser cut option yet available. I'll build it, but I want to do the D.VII first....
  10. DrBill
    DrBill Member
  11. eatcrow2
    eatcrow2 Member
    Here's his web site....
    http://www.kartonowakolekcja.republika.pl/
  12. eatcrow2
    eatcrow2 Member
  13. cgutzmer
    cgutzmer Guest
    YAYYYY! More WWI :)
    Looks great so far!
    Chris
  14. cgutzmer
    cgutzmer Guest
    YAYYYY! More WWI :)
    Looks great so far!
    Chris
  15. milenio3
    milenio3 Active Member
    Very good idea on the plastic rods for a realistic cockpit!!
  16. milenio3
  17. Ben Gal
    Ben Gal Member
  18. Ben Gal
    Ben Gal Member
  19. eatcrow2
    eatcrow2 Member
    detailing the cockpit
    Did some extra detailing to the parts that are going to be making up the inside of the cockpit.. Wood... wire... plastic.. whatever I got lying about that looks as if it'll work..
    [​IMG]
    [​IMG]
    [​IMG]
  20. eatcrow2
    eatcrow2 Member
    cockpit completed
    Added all the parts that make up the cockpit. The fit has been right on the money. Also added some balsa scrap towards the rear of the fuselage that will get sanded to shape.
    [​IMG]
    [​IMG]
Thread Status:
