Focke-Wulf Fw 190 A-8 / Step by step...
Discussion in 'Aircraft & Aviation' started by korvette, Nov 28, 2006.
  1. Amazyah
    Amazyah Senior Member
    And, it is an Halinski design.
    IMO the most spot on kits available.
    Russell
  2. yaniv
    yaniv Active Member
    wow
    no woord my friend sach a nice work
    i have this models 2 copys of it i tray to make it 1 year ago but not a good reasolt so i stop it in the box
    whan u finsh i will start the socend 1 for sure
    i start make a WORD file with all this topic with pic and the words u add for any post
    if u like whan i finsh i can add the file to my website and sher it with all the mebers here :)
  3. korvette
    korvette Member
    Exhaust pipes
    Parts: 14 / 101
      File size:
      159.8 KB
      217
  4. korvette
    korvette Member
    A little bit tricky to shape, but fits very well.
      File size:
      114.2 KB
      226
  5. korvette
    korvette Member
    and the four pipes on every side.
      File size:
      139.5 KB
      214
  6. korvette
    korvette Member
    MG compartment hood
    Parts: 13 / 114
      File size:
      164 KB
      212
  7. korvette
    korvette Member
    Difficult parts to build, due to the necessary shaping. Needs also a lot of time. These parts took me about 4 hours.
    Please notice the two openings on both side of the cockpit (air vents for the guns), compared with the instruction picture. You have to shape them step by step - first I had the impression the part is too large. Dangerouse error if handling glue too fast.
      File size:
      102.6 KB
      210
  8. korvette
    korvette Member
    the front section and the prepared small parts. Glue the front section first in the center and than one "wing" after another.
      File size:
      116.5 KB
      225
  9. korvette
    korvette Member
    finished...
      File size:
      114.1 KB
      215
  10. korvette
    korvette Member
    Hull II
    Parts: 12 / 126
      File size:
      185.7 KB
      216
  11. korvette
    korvette Member
    The same procedure as for the first hull parts. The colouring of the model is very fine, but it costs you a lot of awareness...
      File size:
      139.3 KB
      222
  12. korvette
    korvette Member
    That´s it for today...
      File size:
      139.7 KB
      224
  13. Amazyah
    You sir, are a paper Wizard!8)
    Russell
  14. ekuth
    ekuth Guest
    Looks great!
    Quick question, not being an aircraft guy (yet :roll: )...
    What is the substance you are using to back the former parts with? It looks like it might be balsa wood, but I'm not sure. In other build threads I've seen it appears folks are using a pressed cardboard (like that stuff in shirt packages). If so, what thickness are you using in either instance?
    I can see I'm going to have to build a plane at some point, those being my first loves from my days as a plastic (shhhh!) modeler.
    Of course, I'm fully reformed now and wouldnt dream of making a plastic kit... I havent seen anything that paper can't do yet!
  15. korvette
    korvette Member
    Hi ekuth,
    I´m using ordenary (pressed) cardboard. Thickness is 0,8mm (**-sign) and 0,5mm (*-sign). 0,5mm cardboard is used for all cereal packages or pizza, etc.
    No problems with this material, sometimes I use CA-glue to stabelize sharp edges or thin shapings.
    cheers,
    Korvette
  16. korvette
    korvette Member
    Tailfin structure
    Parts: 16 / 142
      File size:
      137.6 KB
      187
  17. korvette
    korvette Member
    construction process...
      File size:
      124.2 KB
      178
  18. korvette
    korvette Member
    ...finished.
      File size:
      131.5 KB
      183
  19. korvette
    korvette Member
    Tail section
    Parts: 11 / 153
      File size:
      179.1 KB
      181
  20. korvette
    korvette Member
    First the inner parts for the tailwheel.
      File size:
      110.3 KB
      177
