Focke-Wulf Fw 190 A-8 / Step by step...
Discussion in 'Aircraft & Aviation' started by korvette, Nov 28, 2006.
  1. korvette
    korvette Member
    ...framework...
      File size:
      139.9 KB
      310
  2. korvette
    korvette Member
    the closed cockpit - needs some time for clean work.
      File size:
      93.5 KB
      302
  3. korvette
    korvette Member
    Display
    Parts: 9 / 65
      File size:
      187.3 KB
      301
  4. korvette
    korvette Member
    ...development...
      File size:
      162.7 KB
      296
  5. korvette
    korvette Member
    ...after assembling and recolouring...
      File size:
      147 KB
      296
  6. cgutzmer
    cgutzmer Guest
    lookin great! Thanks again for sharing. This seems to have a relly nice level of detail without getting too bogged down in a myriad of details.
    Chris
  7. korvette
    korvette Member
    ...right in position...
      File size:
      90.4 KB
      224
  8. korvette
    korvette Member
    Pilot´s seat
    Parts: 10 / 75
      File size:
      176.7 KB
      233
  9. korvette
    korvette Member
    to compare with...
      File size:
      66.1 KB
  10. korvette
    korvette Member
    ...and inside the cockpit.
      File size:
      107.2 KB
      230
  11. korvette
    korvette Member
    Flight stick
    Parts: 8 / 83
      File size:
      150.4 KB
      269
  12. korvette
    korvette Member
    ...also to compare...
      File size:
      42 KB
      262
  13. korvette
    korvette Member
    ...cockpit nearly finished...
      File size:
      104 KB
      269
  14. korvette
    korvette Member
    Hull I
    Parts: 4 / 87
      File size:
      150.2 KB
      271
  15. korvette
    korvette Member
    Oh boy !
    just 4 parts, but a hell of hard work in shaping and fixing the parts the right way. Nearly 2 hours of cautious building process. The markings are a crucial point. This step is a showstopper for the whole model - if you fail here, throw away the result.
      File size:
      112.2 KB
      275
  16. korvette
    korvette Member
    ...just satisfied...
      File size:
      113.1 KB
      270
  17. Stev0
    Stev0 Active Member
    I am getting the impression that you have built these models already?
  18. korvette
    korvette Member
    Hi Steve,
    Not yet finished...
    I´m building the models, taking pictures from every step. After collecting 40-50 pictures, I start to work out the images for the forum and start to post them. Right now I have 53 pictures of the Fw 190 and I´m working on the tailfin and rudders - comming the following days.
    So my posts are 3-4 days behind the actual built.
    cheers,
    Korvette
  19. Stev0
    Stev0 Active Member
    No I mean are these second builds? As in you have already built this 190 before and the model you are building is a second one?
    Reason why I ask is that the fitments are bang on. I noticed that many builds of this type have alignment hiccups and so far you have not hit any. Like you said above you have a point where it's boom or bust part way through the build.
  20. korvette
    korvette Member
    Hi Steve,
    no, it´s all pure and first built of this model ever for me. I do like the origin models - I even don´t make copys or scans. I appreciate the print, the feeling, the colours, the smell of a good origin cardmodel. And if I fail, doesn´t matter. The prices are not so high, that I couldn´t start a second try.
    For example the Macci Folgore. I failed in the wings structure and dumped the thing. But I will do it again, because it´s a good model and I did the failure. The Ascender from Orlik was a horror and I will never try her again, because the tail section doesn´t fit even with a lot of tricks and work.
    The main point for a lot of aircraft models are the first two hull segments, because they are the reference for the further building process. As for example the Fw 190.
    And another thing: TIME ! You need time to build this hull segments step by step. I do not glue these parts at once - sometimes I start at the bottom line and do need up to 15 steps (shape, glue, fit, dry) until I´m satisfied with the result. Prior to the build, I look for reference points in the construction. The Balkenkreuz and the red 13 for example.
    Well, thats all.:wink:
    cheers,
    Korvette
