F-16 C, 1:33, Halinski 1-2/99
Discussion in 'Aircraft & Aviation' started by fluthecrank, Apr 29, 2006.
  1. fluthecrank
    fluthecrank Member
    Good evening friends,
    today I will introduce to you ma new project ( after the desaster with the F15.......)
    Here is the starting pic:
    [​IMG]
    the main fuselage framework is already finished..........
    [​IMG]
    also the cockpit section........
    [​IMG]
    and the air intakes with integrated front gear bay:
    [​IMG]
    [​IMG]
    [​IMG]
    so far..............FLU
  2. Amazyah
    Amazyah Senior Member
    Hello Flu,
    Looks like your off to a good start!
    Do you build your models from prints made from scans or are you building from the actual model so that there is no turning back?
    I ask because of the F15.
    Russell
  3. fluthecrank
    fluthecrank Member
    Hi Amazyah
    if I´m calm enough to wait for the scanning process.........:grin:
    I try to scan all models before working, like the F-15 but I forgot the formers...............
    And the F16 is build directly out of the kit.................
    best FLU
  4. fluthecrank
    fluthecrank Member
    Hi folks, some more pics.......................
    here you see some more pics of my present project........
    the cockpit section:
    [​IMG]
    the whole fuselage from above:
    [​IMG]
    fuselage including air conduit and nose section:
    [​IMG]
    what´s the world´s opinion ??
    best FLU
  5. Ashrunner
    Ashrunner Member
    Good start, Flu. The fit of the parts appears to be very good also. Although I wish the F-15 was still on the table. 8v)
    Ashrunner
  6. fluthecrank
    fluthecrank Member
    @ashrunner.............
    Hi ashrunner,
    the F-15 will come back.........a freind of my german forum could help me with the formers. ................
    best FLU
  7. fluthecrank
    fluthecrank Member
    front fuselage............
    Hi friends,
    some more pics of the growing front:
    view from above:
    [​IMG]
    ...from the bottom:
    [​IMG]
    and from the left side:
    [​IMG]
    The air intake is still fixed.
    best FLU
  8. GT5500
    GT5500 Member
    Flu you are so good at getting a clean join on your models, care to share any tecniques and tips?
  9. fluthecrank
    fluthecrank Member
    fuselage planking..............
    Hi folks,
    the fuselage planking is nearly finished.............next steps will be the wings.....
    look yourself:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    :-D the camouflage color of the top side is the same as the cutting mat so can hardly see the plane 8) :roll:
    @ GT5500: there is no special tecnique, sometimes everythings fits well and another time it looks like bullsh...see my thread for the F-15......:oops:
    best regards FLU
    sadly I have a business trip so we have to wait for further progress :))
  10. fluthecrank
    fluthecrank Member
    the right wing......with rudder in action ....
    Hi folks,
    here you see the right wing:
    [​IMG]
    [​IMG]
    and the modified rudder............because of some trouble during the changing I need some attempts do get it right, so there are some mismatches
    [​IMG]
    best FLU
  11. jasco
    jasco Member
    What changes are you referring to? Did you scale this model up/down?
  12. fluthecrank
    fluthecrank Member
    only the flaps................
    Hi jasco,
    I changed the flaps. Normaly they are in neutral position, I changed to other position, in my opninion that shows more dynamic..........
    FLU
  13. fluthecrank
    fluthecrank Member
    Hi folks, next step............the left wing !!
    Hi friends,
    some pics of the wings with the load carriers ( view from right front)
    [​IMG]
    left front:
    [​IMG]
    and total bottom:
    [​IMG]
    what´s your opinion ?:roll: :roll: :roll:
    FLU
  14. Ashrunner
    Ashrunner Member
    Flu...the F-16 Fighting Falcon is looking great. I like the idea of giving the model a bit of realism with the flaps. Nice work.
    Ashrunner
  15. fluthecrank
    fluthecrank Member
    Thank´s Ashrunner............
    ............but like in every model there are some small mistakes........I´m still waiting forthe ultimate model......:roll: :wink:
    Here you see the finished jet-nozzle
    [​IMG]
    and a view inside the nozzle
    [​IMG]
    best FLU
  16. fluthecrank
    fluthecrank Member
    and the fin...............
    Hi folks,
    here you can see the fin:
    [​IMG]
    best FLU
  17. Felixdk
    Felixdk New Member
    Your F-16 is coming along beautifully. The view up the tailpipe reminded me of this photo I took of an F-16C at an airshow.
    [​IMG]
    Someone had chalked or painted "Just Married 7413" along with some stick figures in the center of the exhaust and the heat of the exhaust hadn't obliterated it. The heat in that area must be like a blast furnace!
    Don
  18. Bowdenja
    Bowdenja Active Member
    I too think your Falcon is turning out great. Any more work with the Eagle?:-D
    john
  19. fluthecrank
    fluthecrank Member
    The horizontal tail...............
    @ all thanks a lot
    @ Bowdenja: the Eagle is waiting. the lost formers I got from a friend......so be curious ( is this the right diction ??)
    Here is the horizontal tail, movable..........
    [​IMG]
    [​IMG]
    [​IMG]
    and the original..............
    [​IMG]
    Best regards FLU
  20. fluthecrank
    fluthecrank Member
    apparent mistake...........
    Hi folks,
    a friend of our german forum told me about a clear mistake (a designers mistake). For the center of rotation I used the marked piont at the fuselage. But, have a look at the original pic, the horizontal Tail ends nearly with the jet nozzle. I just improved the model..........................
    The original:
    [​IMG]
    and the changed model.......
    [​IMG]
    [​IMG]
    best regards FLU
