Enclave Power Armor build (Fallout)
Discussion in 'Gaming & Toys' started by daishi, Mar 4, 2018.
  1. daishi
    daishi Member
    Ready to start on another Power armor model from the Fallout universe.
    First appearing in Fallout 2, the "Advanced Power Armor" was used by the Enclave. And was the most badass thing you could get in the game next to the M72 Gauss rifle (personal opinion)
    It also appeared in Fallout New Vegas as the Remnant (of the Enclave) Power armor, and quasi retconned by Bethesda as the X-01 in Fallout 4.
    The model is from Fallout 4 and I was originally going to make it with an Enclave paint job, but a modder with the handle Jerros made some brilliant paint-jobs, mostly inspired by "various concepts based on the Vietnam War, WW2 and other military based Sci Fi themes".
    So I couldn't resist making this one using that. I didn't really like the snarling teeth on the helmet so I changed that with a yellow/black stripe, more in line with the armor I used in the game lately .
    As I usually do, I started with the helmet, The eyes are more goldish than silver, following more of the original color scheme than the silver ones used by Jerros.
  2. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
    I have to say that, that I greatly enjoy watching these build threads. It looks like you are off to a really good start!
    daishi likes this.
  3. zathros
    zathros -----SENIOR---- Administrator Moderator
    Everything you build is superb!! :)
    daishi likes this.
  4. DanBKing
    DanBKing Dan the Man
    And he is back at it again......! :) :)
    Another forthcoming masterpiece, I am sure....!
    daishi likes this.
  5. daishi
    daishi Member
    The helmet needs some more work, but the basic shape is done. I will do the piping later with the torso.
    Instead I started work on the legs. Progress is good so far...
    This armor has extensive protective plating on the feet so I did not include some of the overly detailed feet parts in this template, like with the previous two armors.
    The heel and the main actuator housing (I guess you can call it that) is still to be built.
    EPA_WIP_202.jpg EPA_WIP_203.jpg EPA_WIP_204.jpg EPA_WIP_205.jpg EPA_WIP_206.jpg
    EPA_WIP_208.jpg EPA_WIP_209.jpg EPA_WIP_210.jpg EPA_WIP_211.jpg EPA_WIP_212.jpg
  6. zathros
    Running out of words Daishi!! Your skill is worthy of praise. The texturing you give these parts is so authentic. :bowdown::bowdown::Bravo:
    daishi likes this.
  7. Cybergrinder
    Cybergrinder Member Extraordinaire
    Amazing!
    daishi likes this.
  8. daishi
    daishi Member
    Thx!
    For that I cannot take the credit. It is all the "original" ingame texture and my printer. In this case the modded textures made by a modder named Jerros. (He DID do an awesome job on them thou ;) )
    Cybergrinder and zathros like this.
  9. zathros
    Maybe I used the wrong word, "detailing" is more apt! :)
    daishi likes this.
  10. daishi
    daishi Member
    New weekend new update :) ....
    Finished with the other knee and upper leg. While doing that I realized I switched the bottom part of the legs, the ankle joint stub should be on the outer side. Took some scalple work but it is corrected now.
    Also finished with the arms. I intend to make some detachable Tesla nodes for the armor, so added magnets to the appropriate places inside. The placing was done by putting magnets on the outside and putting a magnet i dipped in glue on the inside. The outside magnets are visible on some of the pictures. They were removed after glue on the inner magnets have set.
    EPA_WIP_309.jpg EPA_WIP_310.jpg EPA_WIP_311.jpg EPA_WIP_312.jpg EPA_WIP_313.jpg
  11. zathros
    Very nice. You really know how to make the seams disappear! :)
    daishi likes this.
  12. daishi
    daishi Member
    Thx! I'm using several shades of gray marker pens/brush pens + a technique similar to the one DjPinter described here (http://www.zealot.com/threads/getting-an-almost-seamless-hull.177057/)
    I just use the back tip of my curved tweezers insted of something straight, since I usually do it on curved surfaces. I will try to take a few step by step pictures of this ... if I can remember :p
    lyter1958, Cybergrinder and zathros like this.
  13. DanBKing
    Mmm. I used a similar technique when I built your Frost Dragon.
    I went over every seam with the tips of the tweezers, a bit like pac-man, to shape and blend the seam, following the contours, of course.
    I used water-colour pencils to colour the edges and blend the texture where needed.
    (And BTW: I WILL finish the diorama for the Frost Dragon. Promise.... ;) )
    daishi, Cybergrinder and zathros like this.
  14. daishi
    daishi Member
    I took some pictures to show how I minimalize the visibility of edges. This was made on a a flat part to make it more easy to show, but this works with most curved parts as well.
    First the freshly cut parts get some coloring on the edges, usually with brush marker pens (or what they are called). I have a few different shades of gray (and some base colors).
    When the coloring is done I glue the parts together.
    Then I use the flat back end of my tweezers to push the back part out a bit, and voila.
  15. daishi
    daishi Member
    This weekend I was working on the torso.
    This is the part that will hold the legs, the arms, the helmet, and the breastplate together. It is basically the same Power Armor Frame that I've build for my T-60 with much more details.
    This time I'm only building the parts that will be visible under the breastplate, so much less work. :p
    EPA_WIP_401.jpg EPA_WIP_402.jpg EPA_WIP_403.jpg EPA_WIP_404.jpg EPA_WIP_405.jpg
    EPA_WIP_406.jpg EPA_WIP_407.jpg EPA_WIP_408.jpg EPA_WIP_409.jpg EPA_WIP_410.jpg
  16. Rhaven Blaack
    Thank you for sharing how you minimize the edges. I like the technique. Once I start building again, I am going to have to remember this and try my hand at it to see if I can get the same (or at least close to the same) results.
    This is really coming together beautifully!!!
    daishi likes this.
  17. daishi
    daishi Member
    The weekend was kind of hectic due to Easter, but managed to build the remainder of the foot, and some of the back armor.
    EPA_WIP_501.jpg EPA_WIP_502.jpg EPA_WIP_503.jpg EPA_WIP_504.jpg EPA_WIP_505.jpg EPA_WIP_506.jpg
  18. Revell-Fan
    Revell-Fan Co-Administrator Administrator Moderator
    This looks amazing! :)
    daishi likes this.
  19. zathros
    Using the backsides of pieces attached too tabs is about the only thing they are good for. I advise most people to remove them, as they do not work with them properly, and end up with big gaps showing. This thread shows great technique. Maybe you could address the pros and cons and when you should use tabs, and when you shouldn't, and "tab" preparation to avoid gaps. ;)
    daishi likes this.
  20. Rhaven Blaack
    This is coming together beautifully!!!
    daishi likes this.
