Have you ever wanted to hammer or in some way punish a die that only roll low numbers? I have several
friends that would smash dice that would roll low numbers, one even glued a die back together, with the
result that it now rolls as it should... as many high numbers as low.
I, on the other hand use a cage. On a roll of 1 I will put the die in the cage after I use a marker to color the
highest unmarked side. It stays there until the next game session. After all the sides are colored, I smash the
die and throw it away.
Having said that, here is the design I use to make the cages. I have made several for gifts (birthday,
christmas, ect., ect.)
The last pict is the pattern that I use, the pdf I made was to big to upload.
