Designing T-64B
Discussion in 'Gallery & Designs' started by julescrafter, Mar 27, 2008.
  1. julescrafter
    julescrafter Member
  2. julescrafter
    julescrafter Member
  3. Lex
    Lex Dollmaker
    Just a question Julescrafter... Does that mean you make textures in 3DMax just for rendering, but doesn't actually use it during your unfold, and the unfolded pattern have to be coloured again in Coreldraw?
  4. julescrafter
    julescrafter Member
    Yes you're right, during unfolding, the pattern was still colorless. When all parts were unfolded, I added color using coreldraw. Export them to bitmap for 3D texture. The most hard step was coloring the cammo pattern. Then I must went back and forward between Max and coreldraw, checking the result in 3D, if there's an error I have to fix it in coreldraw and recheck it in Max.
    Jules
  5. Lex
    Lex Dollmaker
    Wow that sounds like a lot of work... how did you get the textures to line up on different parts...?
