Designing T-64B
Discussion in 'Gallery & Designs' started by julescrafter, Mar 27, 2008.
  1. julescrafter
    julescrafter Member
    This T-64B is gonna be a simple and an easy build tank model. 1/43 in scale
    [​IMG]
    [​IMG]
    [​IMG]
    cheers,
    Jules
  2. Stev0
    Stev0 Active Member
    Interesting... kind of a lesser known soviet tank. The numbers in production were very low too. It's no T90 but it's alongside a T72.
  3. Texman
    Texman Guest
  4. julescrafter
    julescrafter Member
    Some of progress
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    cheers,
    Jules
  5. kooklik
    kooklik Member
    Surfaces dividing on turret looks symmetrical. :thumb:Nice design!! Thanks for sharing.
    BR.
    ----kookilk----
  6. julescrafter
    julescrafter Member
  7. lriera
    lriera Member
    It looks very well done to me, congratulations.
    What 3D program do you use?
  8. charliec
    charliec Active Member
    I agree the T-64 development ran parallel to the T-72 but about 13000 T-64s were made. The T-64 lead on to the T-80. I don't think the T-64 was exported from the USSR unlike the T-72.
    Regards,
    Charlie
  9. julescrafter
    julescrafter Member
    thanks Lluis :)
    I use 3D max
    here are the final 3D model,
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    to be continued
    cheers
    Jules
  10. Arjun
    Arjun Member
    Amazing! I've often found the task of constructing such models quite daunting, so I'll just sit back and watch, and hopefully learn something.
    I am currently modelling an American tank (M1 Abrams) in 3ds Max, and haven't yet reached this stage of construction (no accessories yet) and used no mesh-smoothing anywhere. I've never imagined making a paper model out of that yet, especially when I've taken the treads forward quite a bit, making them a lot more detailed- maybe a fresh set of treads for card modelling will come.
    How will you unfold this model? Pepakura seems a preferred option, though I'm more keen on exploring (and exploiting) as many facilities of Max and Photoshop to bypass that application, even if it's hard work. Have you ever used the 'Unfold Mapping' feature in the UVW Unwrap interface? I haven't thought of it yet, as it unfolds in gigantic proportions (if you don't constrain the size- so that you maintain the proportions of all objects). Having said that, texturing will be a little difficult then, in Photoshop.
  11. julescrafter
    julescrafter Member
    Yes, I use pepakura to unfold the parts. Then export them to EPS format to be redrawn by coreldraw. Colors and textures are all done by coreldraw to achive all vector image, I never use photoshop for texturing. I've try unfold mapping in Max but not satisfied with it or I just don't know exactly how to use that feature :p.
    Jules
  12. Arjun
    Arjun Member
    Here's how to unfold geometry- select the mesh (simple as can be) in the UVW interface and then use the Unfold Mapping in the "Mapping" menu. Don't constrain the mapping to the borders (that checkbox should be blank) and you'll get the full size, without any distortion. To use it effectively, cut down the mesh to the simplest units and then run it. Of course, that will result in some huge unfolds, but we can get around that. I've often thought of using it, but it is a little tough to implement.
    I ran a search and found this on the Autodesk website, with pictures
  13. lriera
    lriera Member
    I am reading your dialogue with a lot of interest because I am also using 3D Studio Max, CorelDraw, Pepakura and Photoshop. I want to begin to design my own models soon and I am taking as much information as I can from your posts.
    Thank you.
  14. charliec
  15. julescrafter
    julescrafter Member
  16. Texman
    Texman Guest
    And a Bradley will be cool as well. Thanks Jules!
    Ray
  17. Nothing
    Nothing Longtime Member
    now that is a bad ass looking model! i may have to P.O. the old lady and get this!!
  18. Stormeagle
    Stormeagle Member
  19. cerebrave
    cerebrave Member
    Oh wow! a T-64B...
    I bought it! go get it guys.. Its worth your small money!
  20. BARX2
    BARX2 Member
    I'll be getting it soon. I'm building the M1A2 now.
