Defiant model....where can I post it?
Discussion in 'Internet Finds' started by ARMORMAN, Feb 29, 2004.
  1. ARMORMAN
    ARMORMAN Guest
    I just completed a redraw (in Illustrator) of a ninjatoes Star Trek DS9 Defiant paper pattern. I sent it to him (as a surprise) and have received no response and I wanted to post it for anyone who wanted it....it's a 4.5 or so MEG .pdf file - 10 pages, no instructions (except a quick one I did on page one for one part) and I have not gotten around to build it yet (up to my ears in a FM4 Mecha...verrrrry cool). So, anyone have any ideas?
    Bill
  2. rickstef
    rickstef Guest
    You will have to wait til you get clearance from the original designer, I am a big trekkie, and I would love to have it, but I want to know that you have the permission to post his work.
    til that time, i will drool
    Rick
  3. neoneanderthal
    neoneanderthal New Member
    a 4.5mb attachment as a surprise ... xxxx ... probly pressed delete .. :lol: .... try again ... message only
    n build it first ... lazy xxx :)
  4. ARMORMAN
    ARMORMAN Guest
  5. rickstef
    rickstef Guest
    you can add pictures to your personal album, click on the album button at the top
    Rick
  6. bwallaw
    bwallaw Member
    Hey Guys
    At the ninjatoes site posted by ARMORMAN, the file when you click on the parts download link is a .rar file.
    What kind of download file is a .rar?
  7. rickstef
    rickstef Guest
    similar to a zip file, take a look for winrar, and you should be set
    Rick
  8. bwallaw
    bwallaw Member
    Hey guys
    Brief aside... in the site identified by ARMORMAN for the models in question, the parts download links are a .rar file.
    What is a .rar file?
    (sorry if this is a double-post)
  9. rickstef
    rickstef Guest
    look at my previous post ^^^^^^
  10. ARMORMAN
    ARMORMAN Guest
  11. Bradley
    Bradley New Member
    Defiant
    I for one would love to have your redrawn model. I tried to put the original together and never got it finished.
  12. ARMORMAN
    ARMORMAN Guest
    redraw
    If people want to try the redraw (I have a list of other things I'm trying to complete before I can get to building it myself), I will do one massive email to me on Friday of the PDF file (as I have a 56k modem, it takes foeeeeeevvvverrrr....to upload) to those who are interested. Email me your address at my email: perry@crown.net and make sure that whatever mail service you have can handle a 5 Meg file (I DEFINITELY do NOT want a bounceback of this file).
    A-Man
  13. ButchPrice
    ButchPrice Member
    .rar files
    .rar is a compression format much like zip. There are numerous free and shareware compression programs that can decompress them, WinRar is one,
    IZArc is anouther <http://izsoft.cjb.net>.
    IZArc supports the following archive file types:
    7-ZIP, A, ACE, ARC, ARJ, B64, BH, BZ2, BZA, CAB, CPIO, DEB, ENC, GCA, GZ, GZA, HA, JAR, LHA, LIB, LZH, MBF, MIM, PAK, PK3, RAR, RPM, TAR, TAZ, TBZ, TGZ, TZ, UUE, XXE, YZ1, Z, ZIP, ZOO
    Note the LZH , used by many japanese sites as well
    And it's FREE : )
  14. ARMORMAN
    ARMORMAN Guest
  15. Masamune_Washington
    Masamune_Washington Member
    Size does matter, less is more, GO VECTOR
    I don't understand. You redrew it in _ADOBE_ Illustrator, right? Vector, yes?
    Then why is it "150 dpi jpegs" and "a 5 Meg file"? I have Ninjatoes' model with reference images all packed into 800Kb ZIP file, why would a more efficient data method be larger?
    If not vector-PDF, how many colors are you using? An 8-bit GIF or BMP wouldn't have compression garbage, and 256-color BMPs compress via ZIP/RAR enormously (though some would complain about the size when decompressing).
  16. ARMORMAN
    ARMORMAN Guest
    It is a medium rez jpeg ART file, not vector (I did not want jaggies); and I did not want to put out the original files. It is also in the million color range.
  17. wunwinglow
    wunwinglow Active Member
    jaggies....
    ...er, it is bitmap files that give you jaggies. Vector files give crisp edges whatever the enlargement factor. If you are getting rough edges from a vector image, it is you printer settings that need sorting out.
    Tim
  18. ARMORMAN
    ARMORMAN Guest
    OK, I wanted to check it out before I responded. Once upon a time, waaaay back when I did technical Illustration for a living, when we output Illustrator docs to pdfs, they looked and printed jaggy, so because the screen preview in the more recent version of acrobat showed the parts as jagged, I assumed that it would print the same. As I have just printed out another file that was an illustrator pdf and it printed smooth, I was wrong.
    Sorry.
    :oops:
  19. rowiac
    rowiac Member
    Armorman,
    To get rid of the "jaggies" when viewing Acrobat files, go into Edit / Preferences / General... and then check the box for "Smooth Line Art". This changes how the vector images are displayed on your screen. At least that's where it is on Acrobat 5. I assume it's similar on version 6.
    Hope that helps.
    Roger
  20. charliec
    charliec Active Member
    Acrobat 6 is a little different - there is a "smoothing" option under preferences which has "smooth text", "smooth line art" and "smooth inages"
    turned on by default.
    Regards,
    Charlie
