cutting small disks
Discussion in 'Tips, Tutorials & Tools' started by johnflys2, Apr 15, 2007.
  1. johnflys2
    johnflys2 Member
    I am cutting small disks 3mm, 7mm and 8mm and as would be expected they need a little rounding. I find while sanding the edge of the disks the fibers show slightly. How is this normally treated? John
  2. johnflys2
    johnflys2 Member
  3. shoki2000
    shoki2000 Active Member
    You can use CrazyGlue to stiffen the parts before sanding. This will eliminate the fuzzy edges.
    Personally I would use hole punch to cut those disks - they give nice straigth edge...
  4. shoki2000
  5. johnflys2
    johnflys2 Member
    Crazy glue
    Using crazy glue won't affect the color of graphics on the disk? I know that stuff wicks into whatever you apply it to. John
  6. johnflys2
    johnflys2 Member
    Crazy glue
  7. shoki2000
    I usually use it in small amounts on the reverse side of the part. Works well for stiffening narrow bulkheads so they don't collapse under the skin segment.
  8. shoki2000
  9. johnflys2
    johnflys2 Member
    super glue
    Darn! I guess I may have to use that stuff. Every time I do, I get stuck to something:( John
  10. johnflys2
    johnflys2 Member
    super glue
  11. sakrison
    sakrison Member
    I keep two kinds of superglue on my workbench--brushable ("Elmer's") and gap-filling. I use the brushable stuff to strengthen small bulkheads and other parts and to strengthen joints, and I use the gap-filling stuff where I need a strong joint but have a loose fit. The brushable stuff discolors some but not all inks, so I usually use it on the backs of visible parts.
    I sometimes use a toothpick to apply the brushable stuff to a visible because that allows better control. But you have to work fast; it dries fast.
    --David
  12. sakrison
    sakrison Member
    --David
  13. charliec
    charliec Active Member
    If you don't like Super Glue you can use Acrylic Artists Varnish - just sand down to part to approximately right - apply some varnish to the fuzzy edge - let dry and sand off with fine paper. Acrylic has advantages because it won't affect print colours and certainly won't stick everything in sight (fingers, tools) to the part.
    Regards,
    Charlie
  14. charliec
    Regards,
    Charlie
  15. cmdrted
    cmdrted Active Member
    I use a little wood glue, the stainable stuff from titebond. It also doesn't affect the ink and doesn't burn up my sinuses as much!
  16. cmdrted
  17. paper warrior
    paper warrior Member
    I just use scissors and make one long cut aaaalllllll the way around, haven't had any problems with it so far.
  18. paper warrior
  19. mellotronage
    mellotronage Member
    For small discs, I use a leather punch tool. They can be found in craft stores and have a rotating end for different sizes. The newly made discs of paper will sometimes stick in the end of the punch- just pick 'em out with a #11 blade. Perfect discs every time, no sanding no CA glue.
  20. mellotronage
    mellotronage Member
