Colt SAA peacemaker
Discussion in 'Gallery & Designs' started by Nothing, Dec 22, 2008.
  1. Nothing
    Nothing Longtime Member
    ok folks.by popular concensus i begin.(i dont foresee a 25% jump in votes in the next 12 hours) i am still pondering the options, but that will work itself out later. i started with the cylinder. it will help with proportions on the rest. i have a good side line drawing from a gun manual (thanks silveroxide:thumb:) and i have a copy of colts original SAA patent. some items i am unsure of how difficult it would be to build in paper such as the small depressions in the cylinder side.
    so here is the beginning...
  2. Mousemuffins1
    Mousemuffins1 Member
    I think as long as you leave the option for just a textured version, it shouldn't matter if it's a wee bit complex. the way I did mine on the '51 wasn't really a doable method from the printer, so to speak. Still, I'm sure it can be done, they'd just need to be (probably) added from the inside of the cylinder before closing it up.
  3. Nothing
    i did the barrel next and started blocking in the frame. once i get a few more shapes done i can can start molding it. i had to ditch the manual drawing in favor of a side view photo.
  4. Mousemuffins1
    Looking fantastic. Can't wait.:thumb:
  5. Nothing
    i have enough now to work with. just need to start molding.
  6. silveroxide
    silveroxide Well-Known Member
    A good start with the cylinder first. The indentations are a (rhymes with witch)..... but laminating from the inside and a dremel can help. The hardest part I believe, will be the Chamber guard and the pivoting chamber load door and hinge. The rest should fall into place. Good luck on your build, I am looking forward to the first build installments.
  7. Bowdenja
    Bowdenja Active Member
    Cool! One request............ 4 5/8" barrel. This extends just past the ejector shroud and looks very mean from the business end. Especially in .45 cal Long Colt.:thumb:
    If you are not going to make the cylinder spin then the locking dents will not be necessary and can be done in print detail. IMHO.
    Great job so far!
    john
  8. Nothing
    well im going to do 4 3/4, 5 1/2, 7 1/2 and 12 inch barrels.
  9. Nothing
    started the molding process...still a lot more todo...
  10. Bowdenja
    Neat!
    Wish I could help you out with pics.......... but I got a Vaquero instead of a Peacemaker.......... sign1
  11. Nothing
    i used to have a vaquero. i loved that gun!
  12. Nothing
    work is proceeding rather smoothly...
  13. Nothing
  14. Mousemuffins1
    wow. this thang's getting purdier by the miniute. Are the grips the same as on the '51?
  15. Nothing
    the grips are similar. but im gonna work em differently on this one.
  16. Nothing
    spent the night messing with the loading port and worked up the barrel options.
  17. Mousemuffins1
    oh my, that IS a long one. Does it come with one of those "Bang!" flags?:mrgreen:
  18. silveroxide
    I see that you have a buntline special, you going to work on the detachable shoulder stock?....
  19. Nothing
    no im not going to mess with the stock. sorry.
  20. Mousemuffins1
    I'm going to go with this version:
    [​IMG]
    [​IMG]
    ..I know that strictly speaking it's not a colt (they're Italiian copies, I believe..), but I'm a sucker for a Clint Eastwood western.
