Cathédrale de Reims, L'Instant Durable
Discussion in 'Architecture Models' started by fluthecrank, Dec 9, 2007.
  1. fluthecrank
    fluthecrank Member
    I wish you a happy new year myfriends !!!
    It`s done once more........:thumb:
    just for amusement my gallery pics, I hope you enjoy it............
    [​IMG]
    Shot with PENTAX K100D at 2008-01-02
    [​IMG]
    Shot at 2008-01-02
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Shot with DMC-TZ1 at 2007-12-28
    I hope you like it.................flu
  2. Elliott
    Elliott Senior Member
    Magnificent! The first picture in your last post is particularly beautiful. The birds-eye views are also striking. As you have said, in some of the pictures one can feel the massive weight of the structure, a tribute indeed to both the designer and the builder.
    Thanks once again for sharing your talent with us.
    regards,
    Elliott
  3. B-Manic
    B-Manic Peripheral Visionary
    Absolutely beautiful. Just like the real thing only cleaner. Thanks. :thumb:
  4. shiftdel
    shiftdel Member
    Very impressive model, and a great build, contratulations!!
  5. cgutzmer
    cgutzmer Guest
    How could we not like it????? Super! Awesome photography to boot!
    Chris
  6. Mauiman
    Mauiman Member
    That is a awesome and highly detailed structure. Good job on it.
  7. NorCalWM
    NorCalWM New Member
    Your model came out fantastic ! I'm working on the same cathedral right now. I discovered early that the large side aisles needed quite a bit of supports - doubled up under all the buttresses -just to shore things up a bit.
    Question: did you paint/dye your cut edges? if so, great job ! What do you usually use to cut down the glaring white edge cuts.
    Again, great work !!
  8. Sticks-N-Stones
    Sticks-N-Stones New Member
    Wow! This model turned out very nice. All those tiny statues and pillars must have been time consuming.
    NorCal, I use various shades of watercolors on my edges. You can go fancy at the art supply but an inexpensive color set from the grocery store will do almost as well. Red and green make brown, etc. Apply the color carefully after assembly and try not to get glue on the edge so the color will soak into the paper. Thin the color and if it's too light add a little more pigment. You can always go darker but not the other way.
  9. ravi.rail62
    ravi.rail62 New Member
    Absolutely colorful and coming out very well. Especially impressed with print quality. All the best and a happy new year.
  10. ducapacca
    ducapacca New Member
    Absolutley amazing! Gothic architecture is my favourite and Reims is for sure one of the best cathedral in France. Congratulation on your work
