card weight question - US weights.
Discussion in 'General Card Modeling' started by keith, Apr 22, 2006.
  1. keith
    keith Member
    Hi all,
    What is the most widely available card stock in the your country?
    Alot of modellers seem to use 65/67 and 110 lbs, 110lbs seems like specialist card? Whats the weight of the general purpose card in walmart/asda/etc?
    I'm asking because i want to do some layered card models that will require sanding, so a standard weight would let me work out how many layers to use.
    Also alot of cheap printers do not have a flat tray so the card must go through rollers, i've read that 280gsm(74lb?) is near enough the maximum weight you can use trough rollers. So that might restrict the weight used in the designs.
    I've not worked out yet wether it's better to sand thick card with less glue or thinner card with more glue. Anyone got any experience in sanding card?
    In the uk, 210gsm(56lb) is fairy easy to get, i'd have to go searching for heavier weight it seems. But i'm more interested in global standard weights of card.
    Thanks,
    keith
  2. keith
    keith Member
    Hi all,
    Thanks,
    keith
  3. Al hazlet
    Al hazlet Member
    The typical cardstock I buy at Walmart for $5 per 150 sheets is 110lb stock.
    I've got two HP inkjet printers, both have rollers, neither has any problem with the 110lb stock.
  4. Al hazlet
    Al hazlet Member
  5. Kaz
    Kaz Member
  6. Kaz
    Kaz Member
  7. SCEtoAux
    SCEtoAux Member
    Yep, 110 lb. cardstock seems to be readily available. I get it at Wally World/Sam's. No problems going through the HP printer. Office supply stores like Office Depot have 65 lb cardstock. No problems going through the HP printer.
  8. SCEtoAux
    SCEtoAux Member
  9. keith
    keith Member
    Darn it, I just paid that(£2.50) for 20 sheets of 210gsm (56lb). :mad:
    Now i'm working out wether I could save money on a trip to walmart from the UK, i could go bass fishing while i'm at it :D
    Thanks for all the info, i'll upgrade to the heavier weight.
    QUESTION : is that index, bond or cover?
  10. keith
    keith Member
  11. Amazyah
    Amazyah Senior Member
    I do not know if you have an office supply store in your country
    named Office Depot or not, but I buy both 110 lb and 67lb from them.
    Both are the same price of $2.04 for a pack of 250 sheets.
    That's $3 less than Wal-Mart and 100 more sheets.
    Maybe you have a similar large office supply store there.
    That's the type of store I would look for and check first.
    Russell
  12. Amazyah
    Russell
  13. 46rob
    46rob Member
    I find that 110 lb paper is a bit too heavy for all but the largest or boxiest models. 67 lb, and sometimes even 40 lb paper gives better results, especially on models with lots of curvature. I design my models to use 67 lb btw. Going to an office supply store gets you better prices and selection on paper. Why would anyone go to Walmart, anyway--for anything?
  14. 46rob
    46rob Member
  15. keith
    keith Member
    ooooo headache,
    i'm a bit confused with what actual card you use, the site :- http://www.cardfaq.org/faq/glossary.html shows you have different types, so when you say 67lb or 110lb, you could all be using quite different thicknesses of card. I've read this thoroughly.
    I did a search for card on an american office supply site, the cheap 110lb card was INDEX card so that would be approximately 200gsm.
    The wausau 65lb is COVER weight, which is 175 gsm.
    Thats not alot of difference.!!!
    You must all be buying cover weight?
    So I think i'm going to do is do a bit of research into major brands card weights in the US and then make sure the thickness of the card i use is avaiable everywhere. 300gsm maybe.
    Thanks
    keith
  16. keith
    keith Member
    ooooo headache,
    Thanks
    keith
  17. Gil
    Gil Active Member
    Paper Weight vs. Thickness
    Hi Keith,
    It becomes much easier to use a digital caliper to measure the thickness of the stock. Paper weight doesn't really mean that much but thickness does. Harbor Freight sometimes has a 6 inch digital calipers on sale from time to time which will take all the guess work out of it. Paper is also measured by thickness or "caliper" measured in inches or in millimeters. A good site for this if it hasn't already been mentioned is here:
    http://www.paper-paper.com/weight.html
    Just remember which "Column" you're in...,
    -Gil
  18. Gil
    Gil Active Member
    Hi Keith,
    -Gil
  19. shoki2000
    shoki2000 Active Member
    Hi Russell,
    Is this the regular price for paper and which brand?
    The cheapest cardstock I ever saw in Office Depot runs around $10 for 250 sheets....
  20. shoki2000
    Hi Russell,
