Card Stock Sizes?
Discussion in 'Tools of the Trade' started by RichBohlman, Oct 13, 2006.
  1. 46rob
    46rob Member
    Try Office Max--I always find good buys on 67 and 100 lb stock by Wausau.
  2. 46rob
    46rob Member
  3. RichBohlman
    RichBohlman Railroad Card Modaler
    THANKS Everyone for the great suggestions and help! Rich
  4. RichBohlman
  5. BobH
    BobH New Member
    I have been using Wausau Bright White 65 lb. cover weight paper lately.
    It's much whiter (brightness 96) than the other papers I was using.
    Not cheap but, to me, it's worth it. I got it at Staples.
  6. BobH
    BobH New Member
  7. xyberz
    xyberz Member
    What's the best weight paper to use? Actually what's the best type of paper to use also? I know there's photo paper, matte paper, etc. So many different choices but being someone new to paper modeling, I'd definately like to use the best.
    I've been using 20lb copy paper and gluing 2 sheets together. It's been working pretty well for now I guess.
  8. Art Decko
    Art Decko Member
    I've tried using heavy photo paper (up to 280 gsm). While you can't beat it for richness and depth of color, compared to cardstock, it is harder to cut, score and fold. You can't score the printed surface, and because of the plastic-like surface coating, it resists sharp folds. It's almost like dealing with thin sheets of vinyl.
  9. nikischutt
    nikischutt New Member
    Howzit
    Here in South Africa we use the metric system, i.e. gsm (grams per square metre), so what is 67lb and 110lb in gsm?
    Niki
  10. RichBohlman
    I now get my paper locally! :) Thanks everyone for the help! Rich
  11. xyberz
    xyberz Member
    Damn couldn't find a coversion for GSM. Only just gram and 260 grams equals 0.52lbs. Now that doesn't seem right. :(
  12. Rick Thomson
    Rick Thomson Member
    67lb is about 140g/m2, I've yet to find that weight in Europe though, so I use 160g/m2 which is close enough for me. I expect that 110lb would be about 200g/m2.
  13. xyberz
    xyberz Member
    Wow if that's the case then 280GSM is pretty thick paper! Must come out with some hefty models. :wink:
  14. rlwhitt
    rlwhitt Active Member
    I think it also depends on brand as well. I'm currently using Wausau 65lb that also has 175 g/m2 printed on the label. Go figure...
    Rick
  15. Art Decko
    Art Decko Member
