Card Stock Sizes?
Discussion in 'Tools of the Trade' started by RichBohlman, Oct 13, 2006.
  1. RichBohlman
    RichBohlman Railroad Card Modaler
    On many card models I've seen such statements as: Glue to Light, Medium, or Heavy card. What sizes are these cards really and where can one buy card stock for models? Thanks - Rich
  2. RichBohlman
  3. Amazyah
    Amazyah Senior Member
    Good Morning Rich,
    Your up early!
    I believe a light card would fall in around 67lb a medium about 80-90lb and heavy at 110lb. Just to give you a better idea, normal copy paper is about 20-22lb.
    The best place that I have found to buy the 110lb card is Walmart. You can get a pack of 150 sheets for about $5.
    I wish Walmart carried the other wieghts but I have not seen it there yet.
    They do carry white card and a pack of 5 pastel colors though. It's 110 also.
    The lighter cardstock I have had to shop around for deals. Usually I get them at Office Depot and Michael's. Sometimes you can find a good deal at Hobby Lobby.
    I'm not sure what stores are available in your area but shop around at local art and craft supply stores.
    Hope this helps a little.
    Russell
  4. Amazyah
    Good Morning Rich,
    Your up early!
    Russell
  5. RichBohlman
    All the stores that you stated in your post are in my area.
    Yep, it is early - I'm a 911 dispatcher getting ready to go to work.
    THANKS - Rich
  6. RichBohlman
    THANKS - Rich
  7. RichBohlman
    I just found a good deal on eBay. 250 sheets of white 110 lb paper stock for $14.00. The price included shipping. Thanks Again - Rich
  8. RichBohlman
  9. Amazyah
    You could have bought 2 packs at Wal Mart for $10 and had 300 sheets and no wait.
    Russell
  10. Amazyah
    Russell
  11. RichBohlman
  12. RichBohlman
  13. Bowdenja
    Bowdenja Active Member
    Rich......... it's even labeled "Card Stock" at Wal-Mart. This is what I use almost exclusively, except when I laminate it to card board like what cereal boxes are made of. The package is wrapped in plastic and keeps very well if stored for a long time.
    The only problem I have with the paper is ink bleeding......... but if I set my printer to glossy paper and print at high it doesn't bleed at all, just takes longer to print out:grin:
    You may have to experiment with your ptinter setting, I use a Canon i475D printer.
    john
  14. Bowdenja
    john
  15. cgutzmer
    cgutzmer Guest
    I use matte paper heavyweight and set it to best photo quality. Never had bleed problems with that. My guess is using the photo option is key. I do have to make a run to office depot to get some 67 lb though. Could use some more 44 to bt that can wait :) I use an epson stylus photo r220
  16. cgutzmer
    cgutzmer Guest
  17. SCEtoAux
    SCEtoAux Member
    Sam's Club has 110lb/199gsm cardstock in a pack of 250 for around $5 US. The price might have gone up a bit since the last time I bought some, but probably not too much.:)
    I have to go to Office Depot for 67lb cardstock also.
  18. SCEtoAux
    SCEtoAux Member
  19. Larry Marshall
    Larry Marshall Member
    You can get 110lb index stock from Staples for about $12 as well. Buying paper via eBay doesn't seem to make much sense.
    Cheers --- Larry
  20. Larry Marshall
    Cheers --- Larry
