bumblebee bot build
Discussion in 'Science Fiction & Fantasy' started by Nothing, Aug 5, 2008.
  1. CK Styles
    CK Styles Senior Member
    Looking good Nothing. Keep it up .....
  2. Nothing
    Nothing Longtime Member
    heres the hood and grill
    and i put the plates on the hood
    now at point 1 i stretched and squeezed the head light assemblies
    and glued the hood at points 2.
  3. SEBRET
    SEBRET Member
    Looking great Nothing. any warnings or advice that you would give to others just starting the model? keep up the good work.
  4. Nothing
    the advice i would give is TAKE YOUR TIME! most of the sub assemblies, at least for the torso,(and there are a lot of them) dont have attachment points to speak of. i take each little section cut them out only, and spend a great deal of time examing the instruction pics and the pics at paper inside to try and cypher their placement. ive made 2 mistakes so far. 1 one headlight is upside down.(wasnt paying attention) and the other was on the neck joint. didnt understand how the joint worked at first. so i will have to figure out a didderent way to get it to move. if you run into any problems ask.
    im hoping this thread will help make clear the placement issues.
  5. Cláudio Dias
    Cláudio Dias Member
    Hey Nothing,
    All parts at the torso are 'simply applied' one over each other. You did a great job !
    Thank you for making it clear to other people interested on building the Bumblebee:thumb:
  6. Nothing
    ok got the center hood on
    and completely botched the pipes.
  7. CK Styles
    Are these parts the same from the arm parts pages, made twice for this model (once for the torso and once for the arms) or are you using the parts from the arms that should be already made. I ask as these parts are not in the Torso parts pages. A bit confused as this is where I am in the building stage.
  8. Cláudio Dias
    Cláudio Dias Member
    CK, the joints between the arms and torso come from the arms pages. Please, take a look at the arms instructions. You can read at the first page, taht some parts should be used when building the torso.
    Sorry for the confusion...
  9. CK Styles
    Hold the phone! I think I figured it out. This would explain the extra parts from the arms that were not used that I threw away after I finished the arms! Drats, looks like a reprint for me! Let this be a warning to all, do not through these parts out if you do the arms first (D8, D9, D6). It appears they will be used later. Let me know if I am correct here. These parts were not asked to be built in the arm instructions, so I figured ........
  10. CK Styles
    Thanks Claudio, you are correct, of course. It does state at the beginning of the arm instructions that these parts will be used on the torso, I just need to read before I build I guess!
  11. Biroka
    Biroka Member
    Hy! I'm building bumblebee too. The only thing missing is the body....but I'm stuck at connecting L11 L13 L15 L17 piece to N18. I can't figure it out how they are matching. Some help would be appreciated.
  12. Nothing
    let me see if this helps. i had trouble here as well.
    on mine however i attached the headlight assemblies before putting to the armature. it helped me getting it lined up.
  13. Biroka
    Biroka Member
    Can't see the image! :((
  14. Nothing
    even if you click on it? they are working on the problem but if i clik on the place holder it opens in a new window.
  15. Biroka
    Biroka Member
    I see it now....but still the #1 signed flap is much longer then the length of #2 gluing surface (or how can that be called). I mean the other two flaps fit, but the last one hangs out. Sorry if I'm not understandable.
  16. Nothing
    hey sorry for late response no email notifications. yes mine hanges out a little to.
  17. Biroka
    Biroka Member
    No problem! I looked at the pictures a hundred times and managed to do something similar. BTW are you on hold whit this project?
  18. Nothing
    ive been on hold for a bit.too many things in my life right now.im trying to get back on it.
  19. ikariya
    ikariya New Member
    [​IMG]
    Just finished up the head today! added some pieces to make the jaw pop out more =) Torso is next! I'll prolly pop in if I have problemz.
  20. Biroka
    Biroka Member
    It looks great! It reminds me when I was at that stage....ouch, so many work after that. Hope I will finish mine today...so I will post some pictures of the final result.
