Building the Walthers N Scale Coke Oven
TruckLover
Mack CH613 & 53' Trailer
Apr 14, 2006
4,073
Rancho Santa Margarita, Cali.
Hi guys, this thread will be just like my last thread, "Building the Walthers N Scale Blast Furnace" exept it will be the Walthers N Scale Coke Oven & Quencher.
I should start posting pics in about a week because I don't have the building yet, I ordered it from Mike Fifer Hobby a few days ago and sent out the payment on Monday so it should be here sometime next week.
You can view the thread "Building the Walthers N Scale Blast Furnace" by clicking HERE. You have to click the links to the pics through most of the thread because we moved servers and the pics got messed up but the weathered pics of the furnace at the end are still there.
Hope you guys enjoy this thread as much as you guys did the last :mrgreen: :mrgreen:
Here is a pic of the Walthers Coke Oven from Walthers web site
This build will be entered in the "Spring 07' Kitbuild Challange" here on the Gauge.
TruckLover
Apr 14, 2006
4,073
Hey guys, it came today!! I am building Kitbashed Rolling Mills first cause that contest ends first so I should start building and posting pics of the Coke Oven next week. Be sure to check out the Kitbashed Rolling Mill Thread right HERE for progress shots as I build/kitbash 2 Walthers Rolling Mills together.
TruckLover
Apr 14, 2006
4,073
Here is the Outer End Wall for the Lower Coal Bunker Section. It has some access doors. The Brick Wall was also sprayed Primer Grey with the Roll-up Door and Personel Door begin sprayed a lighter grey.
Here is the Lower Coal Bunker Assembly. The Coal Bunker will sit ontop of the supports at the top.
TruckLover
Apr 14, 2006
4,073
The Coke Oven Walls have been sprayed a rust color while the Brick Oven Walls were sprayed the grey primer color.
Oven Top has been sprayed a tan color and glued in place ontop of the oven walls. The Oven Top will be weathered with bits of brown, black, orange, and red colors and the walls will be weathered the same way.
TruckLover
Apr 14, 2006
4,073
Here is the top portion of the Coal Bunker which has been sprayed the rust color. The black part is where it will be sprayed an aluminum color as it is aluminum siding.
Aluminum Siding sprayed.
Added the roofs to the Coal Bunker. The opening is for the conveyor that will come from the Crushing House.
TruckLover
Apr 14, 2006
4,073
Josh W, thanks man, I am really looking forward to weathering this awesome building to.
Josh, Thanks, your project is looking really sweet to, those railings and stairs look amazing!!!
nscaler, Thanks again, I really like that blast furnace, it is bigger then any of my HO buildings lol
TruckLover
Apr 14, 2006
4,073
Okay, finally made a lil progress today. I have been busy and havn't worked on coke oven for a few days now. I better step it up lol, I need to finish by the 31st so I can make the deadline for the contest :mrgreen: and I still gotta weather it to
TruckLover
Apr 14, 2006
4,073
Here is the stairwell that goes from the ground up to the top of the ovens. This is the unpainted pic.
Here is the painted Stairwell. I sprayed it a bright safety yellow which will be weathered to look used.
TruckLover
Apr 14, 2006
4,073
Govonor House has been built and sprayed several diff colors including Rust color for the support structure, Silver for the aluminum sheeting walls, and grey for the door to the Govonor House
Govonor House Rear. You can see the Collector Pipe going in the Govonor House.
