building my own snowspeeder
Discussion in 'Science Fiction & Fantasy' started by dnalor, Jul 24, 2012.
  1. dnalor
    dnalor Active Member
    Yes, the engines are ready..
    so i started with the next parts.
    its that gun mounting point.
    i hope this is easier then the engines.
    Also i still need to make those 2 exhaust-ports.
    i need to make somehow some good tubes..that look thick.
    12525
  2. DanBKing
    DanBKing Dan the Man
    Guns of dnalor...
    These might work.
    Cheap too.
    Wrap em in paper, and they should be bulky enough..
    Dunno if the diameter is correct though..
    Balloon sticks
  3. dnalor
    heeee that could be it...
    thanks.
  4. dnalor
    just again a little step
  5. zathros
    zathros -----SENIOR---- Administrator Moderator
    The detail work on this model is so detailed. Es ist unglaublich! :)
  6. dnalor
    well,
    i hope when this ship is finished...that i have a ship what looks like a nice replica...
    or something close to that.
  7. zathros
    I believe that is a short time away. It is just amazing. You can't buy something like that, so that means you have something that few, if anybody, has. :)
  8. Rogerio Silva
    Rogerio Silva Active Member
    If all the time, effort, and unbelievable detailing you have put in this model don't make it an ABSOLUTELY FANTASTIC replica, then I can't possibily figure out what it'll be.
  9. dnalor
    just a little update.
    I cut out the panels..
    then glue them on the paper with the colour of speeder.
    cut them out again..
    and glue them in to place..
    don't forget the screw holes this time..
    12976
  10. dnalor
    Yes.. after a long time a little test fit..
    it looks nice.
    only thing i don't understand is why the tube is off like this..
    it should stand correct...hum.
    i have to study the studiomodel again...maybe i see what's wrong with mine.
    13050
  11. DanBKing
    Mmmm.
    The cannons seem more offset at the back than at the front .....
  12. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
    Try switching out the back sections.
    I think that will solve your problems.
  13. zathros
    The tubes converge. It is obvious in the drawing above. :)
  14. imcold
    imcold Member
    But not by that much. It looks to me like the back sections are a bit too big, but hard to say without ortho photos.
  15. dnalor
    hum..
    i replaced the gunrods..
    they look better but the middle section is now to low..
    i think i will i keep it like this and mask the little error :)
    [YOUTUBE]WnvTpfKuAUU[/YOUTUBE]
    Imcold do you really think that the engines are to thick?..
    the orginal engines looks so small when i installed them..
  16. imcold
    imcold Member
    The sidewalls on the aft boxes seem a bit too steep, but I don't want to talk bs. I'll peek through my references later today and I'll let you know. Anyway, you can mask it by breaking the rods in the forward boxes, it doesn't have to be perfectly straight from back to front.
  17. dnalor
    i think that i will do something like that to get it right :)
    rebuilding the back engines is a no go...(for me) they look to nice...
  18. Rhaven Blaack
    The components that I have circled, just switch the whole components out (put the left one on the right and the right one on the left). I think that will solve your problem.
  19. dnalor
    that is not possible..
    The details of the armour panels are different of the side and the top.
    I think i will mask the error with the engine details, the pieces that are white on the wings see picture (under the rods)
  20. zathros
    It's not so much that the parts are reversed it is that the trapezoids are not correct. The longer side should be on the wing and the shorter connecting to the cockpit (with the flat). You could just center the tubes as necessary and redraw the fronts of the trapezoids to correct the situation. I think this could be an easy fix with your talents. IMHO. :)
