Building a Traction Layout
Discussion in 'Traction Thoroughfare' started by interurban, Jul 5, 2005.
  1. Nazgul
    Nazgul Active Member
    Chris
    I can only imagine the careful work and patience that must go into a layout such as yours. It must, however, make it all the more rewarding to see all of your hard work payoff in such a spectacular way!:thumb: :thumb: Keep up the outstanding work!:) :) :)
  2. spitfire
    spitfire Active Member
    Well now Chris, if that's an invitation.. I might just have to go ahead and get one!!! :D :D
    Val
  3. interurban
    interurban Active Member
    Cabin looks cosy as the night draws nigh
    Here is a dusk scene from the snow scene area.
    Lots of things on the go, so progress is a bit slow at the moment
  4. MasonJar
    Great pic Chris - I can almost smell the woodsmoke...! ;) :D
    Andrew
  5. jetrock
    jetrock Member
    Here's a question: How hard is it to manually uncouple cars under wire? I was fiddling around with a Rix pick doing some switching last night and said "geez, if I had overhead I'd be slashing myself to ribbons right now!"
  6. green_elite_cab
    yeah i'm curious to, as it just occured to me why catenary will be a problem in the future....
  7. spitfire
    Very Christmas-y!!! I like it, especially the little snowman and the lighting in the building. Very warm and cosy looking. :thumb:
    Val
  8. interurban
    Understand that a combine carries freight so do boxmotors, and maybe the odd trailer, It isn`t necessary to uncuple like you would on the main line if that`s your power choice.
    The juice jacks would do the big haul and I use the magnets like the mail line would in sidings, also a hands on tooth pick or dentist tool helps too.:D
  9. jetrock
    jetrock Member
    Ah, there's the rub: I'm modeling a western U.S. electric, which was characterized by heavy juice jacks doing most of the freight work, rather than combines or box motors. I guess I'll just have to learn to get good with the Rix pick, or put down more uncoupling magnets!
  10. interurban
    The back drop that leads into my snow scene corner.
    Still got to blend them in the bottom areas
  11. interurban
    It`s been a while since I updated this thread, I can now do so as I am on the last section .
    This has been a project on hold until it hit me this week what I wanted to accomplish here.
    So in goes the making of a road on a hill.
    It is ready for the instafill to be spread in, next will be the scenery up from the rails and down the other side where there is located two portals.
    Also there is a business section going in top and bottom.
    This will take a while to finish as the overhead has to go in, you may notice I change the track a bit.
    Last shots of the town platform
  12. spitfire
    Looking good Chris!! I assume the two strips I see are to contain the roadway - plaster, right? I see my favourite building in that shot - man it's a nice one!
    I can't believe how quickly your layout is coming together. :thumb: :thumb: :thumb:
    Mine seems to be taking forever!!
    Val
  13. interurban
    Thanks Val, Yes the balsa strips will keep the road neat, then the earth grass bushes will be added.
  14. MasonJar
    Wow Chris - nice work, and coming along quickly too...!
    That 5 story building is fantastic. Looks great following the curve of the road too. Very different than the usual flats or shallow relief background buildings one usualy sees. :thumb:
    Andrew
  15. interurban
    It`s been a while , but here are a few pictures of what I have been doing with the layout.
    First a shot coming out of tunnel with the scenery finished.
    This is a station I bought already to go great building.
  16. interurban
    I bought this saw pit kit of David, and built it last spring when I was of work getting a knee replacement on the right leg.
    First a picture building it
    Here is the location on the layout.
  17. interurban
    Here she is fitted in and scenery done.
    The kit was a dream to build and one can do many things with it re setting up the scene
  18. MilesWestern
    MilesWestern Active Member
    Looks great! so nice to see progress on your layout once again! :)
  19. interurban
    Illinois traction, prowling around the layaout.
  20. MilesWestern
    Wow, it's been quite awhile! how about some overall shots of your layout?
