Build thread: Millenium Falcon
Discussion in 'Science Fiction & Fantasy' started by causticphlegm, Nov 1, 2007.
  1. causticphlegm
    causticphlegm Member
    You bet. Done. It's just over 9 megs zipped. Hopefully my ISP's famously wonky email server will get it to you in one piece. If it doesn't I can try from either my hotmail or gmail accounts. Let me know.
  2. afcgooners
    afcgooners New Member
    wow great detail. the colours look great. I wish i had patience to build one of these!
  3. OylPslyk
    OylPslyk Aspiring Usurper
    Thanks much!, it came through fine!, in fact it came through 3 times! sign1
  4. causticphlegm
    That's the universe's way of saying announce1"GET BUILDING!!!"
  5. OylPslyk
    cool!, well over 2' when finished...:mrgreen:
    I'm gonna study this one and also plan this one out and do a frame for it 1st.
    I look forward to following your progress!
  6. causticphlegm
    Well, if you can make faster/better progress, post the pics. Don't worry about taking my spotlight. :thumb:
    For the interior frame I'm going to build the underside of the saucer section as carefully as I can, put the included ring frame on it (dry fitting) then make a frame for that. All I'll have to do then is mirror it to support the top section. I'm not too worried about it being perfect. I'm building at 1/2 scale with thick stock so as long as my cat doesn't decide to make it his new plaything, I should be OK. sign1
  7. OylPslyk
    I was thinking of trying to use the core/frame of the model from the SF papercraft gallery (SF PaperCraftGallery) scaling it up, and then trimming or adding to it as needed.
    a long time back I worked up some landing gear to fit that model too, I may try to upgrade those as well for this one!
  8. causticphlegm
    Port side mandible. A lot more parts than the starboard...at least it seemed like it. :mrgreen: Took a lot longer than what I wanted it to.
    [​IMG]
    [​IMG]
  9. cgutzmer
    cgutzmer Guest
    WOW! this is sweeeeeet :)
  10. Nexus9
    Nexus9 Member
    This is really nice. Always loved the Millenium Falcon.
  11. dansls1
    dansls1 Member
    This is looking great and coming together quickly ;)
  12. causticphlegm
    Engine ring. 50+ pieces including my crappy custom interior braces (which you can't see in these pics. As usual bad picture taking. I should start taking them in daylight :thumb:
    [​IMG]
    [​IMG]
    [​IMG]
  13. jaffro
    jaffro Long term member
    I was just thinking the same thing last night while taking pictures of my current build... so after reading your post I went outside (lovely day today) and took a few pics to compare against the flash photos I took last night (using various settings to find the best one, which I didn't).
    I don't have time to post pics now, I'll add them to my build thread later though, because the results were great... I think I'll try to take more pics in sunlight from now on, especially of the finished model once it's done. For inside shots though, I'm going to try some new lighting.
    This model of yours is coming along very nicely by the way, keep up the good work, The more I see of yours, the further it climbs up my build queue. :D
  14. Millenniumfalsehood
    That's looking really good! Keep it up; I want to see this fully built. :)
  15. causticphlegm
    Rear ventral section with landing gear pod. I was worried that there would not be enough curve to these four sections (other 3 will follow) but it turned out OK. I also did the port docking ring, which is almost a mirror of the starboard save a few minor details, so no pics of that one. I was on a roll today but sadly had to clear my workspace (dining room table) 'cause the family is coming over for dinner tomorrow nite...otherwise I woulda got the forward ventral section done, too. Ah well, a productive day nonetheless.
    [​IMG]
    [​IMG]
  16. cgutzmer
    cgutzmer Guest
    Looking great! Appreciate the pics from different angles. A request though. You said you put in some of your own formers - when you scratchbuild an addition or improvement try to get a pic of it for us in case it will help us do a better job if we build the model :D
    Chris
  17. causticphlegm
    Chris, a monkey with a chainsaw and a bottle of crazy glue could do a better job than me. :p
  18. cgutzmer
    cgutzmer Guest
    I must be a monkey without opposable thumbs then cause I gave up on an easier build of the falcon.... ;)
  19. jaffro
    You're entitled to your own opinion, we however, disagree! :D
    This model is coming together nicely and I know I'm not the only one here who can't wait to see how it turns out, but for now we're enjoying the build and you should be proud of it...
  20. Nothing
    Nothing Longtime Member
    i wish yall'd quit calling me a monkey! and leave my super glue out of it!
