Build: Mitsubishi A6M2 Zero, 1:33, Halinski 3/2005
Discussion in 'Aircraft & Aviation' started by rlwhitt, Dec 20, 2006.
  1. cmdrted
    cmdrted Active Member
    Amen to that! I think if you use a flexible endoscope with macro lens you can take a look in there now and again. Great job!
  2. rlwhitt
    rlwhitt Active Member
    Maybe I'll take a picture and glue it to the outside - sort of like an x-ray or a cross section drawing... ;)
  3. milenio3
    milenio3 Active Member
    Now, that's a very good idea. There are many times people don't see those details - more if you are not there to show - and a picture can tell where to look for.... unless you take the model to a competition.
  4. rlwhitt
    Here's the seat hanging on all the brackets from the rear former:
  5. rlwhitt
    The last "inner" cockpit detail is this pipe that holds some sort of panel near the pilot. Next up will be the all the stuff on the cockpit side walls.
  6. Stev0
    Stev0 Active Member
    Message tube??
    *shrugs*
  7. rlwhitt
    Not sure either, but this photo caption from the above design page might hold a clue:
    Right side of cockpit showing, at left, oil shutter and cowl flap adjusting cranks with cockpit ventilating tube seen at end of cowl flap crank.
  8. rlwhitt
    Starting on the cockpit sides/inner skins. This photo shows just the shaped skin with the ribs installed.
  9. rlwhitt
    And the skin with all the "goodies" attached.
  10. rlwhitt
    And finally mounted to the cockpit framework. Note the little hump shape the fuelage has at the forward end of the cockpit. So far so good with fit - this skin fit absolutely perfectly everywhere. Man, that's a good feeling!
  11. cmdrted
    Absolutely stunning! I gotta get me some more of them Halinskis! But its probably the good job you're doing. Great work man!
  12. cardmodeler
    cardmodeler Member
    Beautiful work! This is really getting me in the mood to commence work on the Halinski P-40 I recently picked up.
  13. josve
    josve Active Member
    Very nice! Very nice indeed :)
    Great work!!
  14. rlwhitt
    Right about now after nearly 2 weeks of cockpit detail, I'm eyeing your 2 current birds with more reasonable cockpits! :) Next model I think I'm going to take it a bit easier.
    Rick
  15. cgutzmer
    cgutzmer Guest
    more work in that cockpit (and great work) than in most planes I have done.....
    Chris
  16. rlwhitt
    The completed right inner skin with controls:
  17. rlwhitt
    Before closing in the cockpit, I thought I'd do a dry fit of the cockpit section to the wing assembly, and take a pic so you can see the general fit of the structure.
  18. rlwhitt
    Both inner skins installed.
    Waaaahhhhh, all that cockpit detail hidden! :(
    Just in case anyone wonders, as I did when I started looking at build threads, why there are pictures and writing on the back of the skins - Some kits print a page of parts on the inside of the back cover of the book, obviously an efficent use of paper. So you see here whatever is printed on the back.
  19. rlwhitt
    Here we have the first 3 pieces of skin installed on the cockpit section. The fit so far is great!
  20. rlwhitt
    And next we join the completed cockpit section to the previously completed wing section.
    Here I had some fun and excitement. I made one of my mindless bonehead errors (seems I need to make at least one per model) but I recovered. Let me do a sort-of GoldenBear quiz and see if anyone sees what I screwed up! I think the result is fine, not as fine as if I hadn't messed up, but it's cool.
