[Build from scratch] PzKpfw "Tiger" I
Discussion in 'Armory & Military' started by Przemo, Dec 25, 2004.
  1. Przemo
    Przemo Member
    Hi!
    Next detail...cover for the reduktion gear.Almost ready...:)
    More about this detail You can find HERE
    [​IMG]
    Best regards, Przemo :D
  2. Przemo
    Przemo Member
    Hi!
    Next photos.Interior set...on the photos you can see painted details.
    I also add lubrication system.
    Lubrication cabel
    [​IMG]
    [​IMG]
    [​IMG]
    What do You thing about weld imitation???
    Please write something... :?
    Regards, Przemek
  3. jrts
    jrts Active Member
    Hi Przemo
    How the heck have done that, it looks as if it's real all right.
    You even have the ridges made with the flick of the wrist when welding 8)
    Can you post a photo of the next section of weld un painted so we can see how it was done
    The amount of detail going in to this is just amazing.
    Oh and a few photo's of some of the tools you have used would be great also!!
    Next and soon please :roll:
    Rob
  4. Jim Nunn
    Jim Nunn Member
    Looks great! What did you use? I have used Acrylic Gesso as a filler and thought about using it to make rivets and weld seams.
    Jim Nunn
  5. Jim Nunn
    Jim Nunn Member
    Przemek
    Check out electronic solder for your cables and piping. You can purchase it as small as 12 mils (.3 mm) in diameter that works out to be about 8 mm in 1/25 scale. It is easy to bend and it holds its shape. You can even purchase plumbing solder that is 2 and 3 mm in diameter for larger piping.
    Jim Nunn
  6. Przemo
    Przemo Member
    Hi!
    Sorry for this break, but i had few exams :evil:
    Jim, Rob - thanks for answer and advices :)
    Imitation of weld is made from wikol glue.
    For the pips I used solder from old speakers :)
    Tommorow I will show how looks wikol glue and some triks ;)
    Przemek
  7. stevepax_2000
    stevepax_2000 New Member
    Good Luck
    I hope your exam results were what you were hoping for. This is an excellent review you are posting and it has inspired me (a complete novice) to give it a go.... There's a bloody lot of track segments :)
    Keep up the good work Przemek.
    Steve :)
  8. Przemo
    Przemo Member
    Hi!
    Thanks Steve :)
    I'm sorry for this delay...but I didn't have much time :cry:
    For now I present some photos.
    I have done sockets for crank pins:
    [​IMG]
    [​IMG]
    Crank pins in the sockets:
    [​IMG]
  9. Przemo
    Przemo Member
    I made 1'st crank with pin:
    [​IMG]
    [​IMG]
    Profil of the crank:
    [​IMG]
    Crank with pin in the hull:
    [​IMG]
    Przemek
  10. Przemo
    Przemo Member
    Hi!
    I'm still building track links :)
    [​IMG]
    [​IMG]
    [​IMG]
    Przemek
  11. Przemo
    Przemo Member
    Making imitation of weld with wikol glue.
    This glue is based on water.Before dry wikol is white.After is transparent.
    [​IMG]
    Regards, Przemek
  12. stevepax_2000
    Just Wondering...
    Hi Przemek,
    Just a quick question (refer attached image)
    Steve.
  13. Przemo
    Przemo Member
    I kit 1 teeth from 2 parts :)
    To give good thickness of the teeth.
    Regards, Przemek
  14. stevepax_2000
    Thanks
    You are doing a marvellous job. Your attention to detail is astounding. I think I will continue to do the tracks as provided in the kit, but I have used your images to create plans for next time :)
    Steve.
  15. Przemo
    Przemo Member
    Hi!
    Thank You Steve :)
    I made double tyred road wheels :)
    [​IMG]
    [​IMG]
    [​IMG]
    Regards, Przemo
  16. david n
    david n New Member
    Simply amazing
    The quality, detail and scope of your model amazes me. I build plastic armor models and this rivals those any day.
  17. dimas Karabas
    dimas Karabas Member
    Very nice work. How do you make holes look so nice? What tools do you use?
  18. Przemo
    Przemo Member
    Hi!!!
    Thanks David :)
    Dimas- I make hole with Olfa Desing Knife.Model AK-3.
    It's very sharp.
    Regards, Przemo
  19. Przemo
    Przemo Member
    Hi!
    Couple track links...
    [​IMG]
    [​IMG]
    [​IMG]
    Regards, Przemo
  20. stevepax_2000
    Amazing....
    How long does it take to make each link?
    Yet again, you are showing amazing results. How do you get time to study and indulge in this pastime?
    Steve.
