Build: Fokker F-28 Fellowship
Discussion in 'Aircraft & Aviation' started by milenio3, Feb 8, 2007.
  1. milenio3
    milenio3 Active Member
    Now let's attach the engines. These are relatively easy to built.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. milenio3
    The engines are ready to rumble
    [​IMG]
  3. paper warrior
    paper warrior Member
  4. milenio3
    Thank you!
    Chapter 3, Hack # 4. Now the landing gear. In this case, the design has very simple tires... two circles with a strip. This meant trouble again. It is, as I mentioned, a very heavy plane, so the tires as designed, were not going to support the weight.
    So I managed to hack them too. First, laminate the tire diagram to 1mm cardboard, each circle, so we can have 2mm tires.
    [​IMG]
    And then cut each tire...
    [​IMG]
    [​IMG]
    And sand it to its round profile.
    [​IMG]
    Then paint it black with a marker.
    [​IMG]
  5. milenio3
    Almost done!!
  6. Fishcarver
    Fishcarver Active Member
    Gerardo:
    Good looking build so far!
    Jim
  7. milenio3
    Thank you guys!
    Here are the landing gear in place.
    [​IMG]
  8. milenio3
    The final product. A Martinair Fokker F-28 Fellowship.
    [​IMG]
    [​IMG]
  9. Ponytail
    Ponytail Member
    Fine Result!
  10. Clashster
    Clashster Member
    Looks good enough to fly! Great job, Gerardo! Thanks for the tread!
    Chris
  11. milenio3
    Thank you guys!
    Although the design is not the best around, I think it's a nice model.
    I hope you liked this thread.
    Thank you again.
