Brushless motors the myths
Discussion in 'RC General & Getting Started' started by mastmec, Mar 29, 2004.
Thread Status:
  1. mastmec
    mastmec Member
    Hey Tim, here's another one from Hacker, This is right off there web site.
    This is the Motor to Blow Away all Mods and most Nitro Trucks!!! Extreme Brushless Power is Available Now... C50 Maxx 14.4v - Is a large Motor Specially designed for Electric Monster Trucks with 12 cells in Series. Incredible Speed and Power define the performance of the C50 Maxx Motor. All Motors feature Super Duty Case and 1/8" shaft with flat area.
    I guess you will keep your word and go out and buy one now, right?
  2. timrock
    timrock Active Member
    i am right.you are wrong.click on the link again.that system that says 10-14 cells is for two motors.it even mentions the Traxxas E-Maxx.that truck runs on two motors.
    so like i said.it is 5-7 cells per motor.very limited to the amout of cells you can run.i run 16 cells per motor with brushed motors.my system is Way faster than any stock Brushless motor system availible.
    http://teamnovak.com/products/MOTOR/hvmaxx/hvmaxx.htm
  3. monsterrcbuilder04
    the brushless systeme replaces the 2 motors with one and it is supposed to be better
  4. mastmec
    mastmec Member
    Yea, the T-maxx comes with two motors, the two diferent brushless systems the I mentioned are one motor systems that replace the stock motors and will accept up to 14 cells in series. ONE motor.
  5. monsterrcbuilder04
    tim if you dont belive that it takes 14 cells check out the febuary 2004 issue of rcca if you have it. they have a couple pics of the setup using one motor and it says that you can use two 7 cell batteries
  6. timrock
    what makes you think i dont believe it takes 14 cells?
    14 cells total.7cells per motor.Brushless motor system.
    how many times do i have to post this?
  7. timrock
    Brushless motor systems are limited to the amount off cells you can run.
    Brushed motor systems are much more Powerful than Brushless motor systems.
  8. timrock
    Brushless is a better idea because it eliminates the resistance caused by the brushes rubbing against the communtator.
  9. mastmec
    mastmec Member
    You keep posting the same thing, the same wrong info, either you are looking at the wrong system or can't addmit your wrong.
  10. timrock
    i would like to be wrong about this.i would love to have a Brushless motor system that can run one motor on 14 cells.but there isnt one avalible.if you can post the link to where i can buy it that would be great.
  11. mastmec
    mastmec Member
  12. mastmec
    mastmec Member
  13. mastmec
    mastmec Member
  14. mastmec
    mastmec Member
    I think you have a bunch of stripped gears in your head Tim, or they're jammed.
  15. timrock
    even if it is for one motor,it would be better with two that can handle 14 cells each.so it still stinks either way.my Brushed sytem still would be much more powerful than any brushless.
    although Brushless would be better
  16. timrock
    here you go again bashing people
  17. mastmec
    mastmec Member
  18. mastmec
    mastmec Member
    Oh, and I like that you deleted your post between my last two up there.
  19. timrock
    this is what i mean about his problem.he keeps bashing people who dont agree with him.
  20. timrock
    we are talking about Brushless and Brushed Motor systems.what are you talking about?
Thread Status:
