Brewster Buffalo F2A Fiddler-freebee
Discussion in 'Aircraft & Aviation' started by Triop, Mar 13, 2007.
Thread Status:
  1. cdcoyle
    cdcoyle Member
    Is that a picture of a large-scale RC Buffalo?? :shock: I'd like to know where I could see more of that build.
  2. blueeyedbear
    blueeyedbear Member
    It is the Fiddler's Green Buffalo in approximately 1/60 scale. I just finished building one day before yesterday! I dropped the flaps and elevators, cocked the rudder to port, added guns and gunsight, and changed the plane to a Buffalo I found in Google Images, by adding the fuse number (the cowling number is too small to do) and throwng away the spinner.
    Bob
    (When I figure out how to do it again, I'll post some pix)
    [It is an easy model, they say, I had the devil of a time getting things to fit!!!!!!!]
  3. Triop
    Triop Member
    @ cdcoyle : Find out more here : http://www.sierragiant.com/prod18.html
    @ Golden Bear :
    Thanx for the advice, as a matter of fact I did use tweesers.
    I bought this very cheap set a long time ago...they easely bend as well. :-D
    [​IMG]
  4. Triop
    Triop Member
    ISN'T THIS FUN ?!
    I cut the wheels from this part . . .
    [​IMG]
    . . . and glued them on the outside of the wheels . . .
    [​IMG]
    . . . the upper part of the landing gear I glued on the inside . . .
    [​IMG]
    . . . this way of building also makes it more solid and stronger I think. :-D
  5. Maurice
    Maurice Member
  6. blueeyedbear
    blueeyedbear Member
    Here are some pix of my Buffalo. Hope they help you. Be sure to Google Images ""Brewster F2A Buffalo".
    Bob
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  7. Triop
    Triop Member
    Wow..that looks awesome !
    What are those green things I see under the wings ?
  8. cdcoyle
    cdcoyle Member
    the much-maligned Buffalo
    Probably all of the propeller-heads who frequent this forum are up-to-date on their aircraft history, but just in case anyone isn't familiar with the Buffalo, check some of the links at this site: http://www.warbirdforum.com/buff.htm. Especially take note of the Buffalo's exploits in Finnish hands -- they made the Buffalo seem like a wonder-weapon. I've always had a soft spot for this little airplane, as it is one of the plastic models I built in my youth.
    Regards,
  9. Bowdenja
    Bowdenja Active Member
    Triop....................... Flaps? Maybe.
  10. blueeyedbear
    blueeyedbear Member
    Triops,
    Those "green things" under the wings are the flaps.
    I use Testors Model Master "Zinc Chromate Primer" (acryl or enamel) for interior surfaces like the flaps and inside the cowling and the wheel wells. It is a lot easier than green paper! The zinc chromate is close enough to use inside the cockpit, if you do the interior. I also use silver paint pens and a Testors yellow paint marker for the propeller tips (the chisel tip does the prop tip in a single sweep).
    And for you "paper purists": paint is just about the same as printer ink, except it comes in a bottle and you can put it on where you want with a brush!:grin:
    Bob
    (You can also find the same colors in Railroad model colors, in shops or mail order)
  11. Triop
    Triop Member
    I've cut the wheels out of the fugelage . . .
    [​IMG]
    . . . and glued a green strip on the back.
    [​IMG]
    To bad I can't use the wheels I've cut out...the colour is to dark and I already glued the other wheels on the landing gear...:roll:
    Also glued the cockpit...I was thinking about making it transparent, but the details are to small to cut out...
    [​IMG]
    [​IMG]
  12. MOS95B
    MOS95B Member
    I just signed up, and didn't get this freebie. Dangit....
    Looks like a cool build. Good work, folks!
  13. Triop
    Triop Member
  14. Triop
    Triop Member
    Glued the fuselage . . .
    [​IMG]
    . . . Cut off the " put glue here " bits . . . :-D
    [​IMG]
    . . . placed a paper stroke.
    [​IMG]
  15. Triop
    Triop Member
    I've cut open the rudder . . .
    [​IMG]
    . . . not a very good picture . . .
    [​IMG]
    . . . but it looks alright.
    [​IMG]
    It starts to look like a plane now, pretty happy about the build so far.
    [​IMG]
  16. Triop
    Triop Member
    I never had the pleasure of building this sort of part :roll: ...does anyone have any suggestions on how to glue this ?
    [​IMG]
  17. BARX2
    BARX2 Member
    This will form a cone. Shape the points inward and glue the sides of each point together, all the way to the tip. It takes time, but can produce a decent spinner.
    Oh, I almost forgot to add: First you join the glue tab to the opposite side of the piece so it's a ring, then glue the points.
  18. MOS95B
    MOS95B Member
    Now i see it!! The part didn't make sense until Barx spelled it out.
    I hate those kind of parts... Wash your hands and get to work, Triop...
  19. Triop
    Triop Member
    :grin: thanx ! . . . I'm on it ! :grin:
  20. Triop
    Triop Member
    It's been a while...but here is a update :grin:
    Glued this...
    [​IMG]
    ...so it lookes like this...
    [​IMG]
    Cut this away...
    [​IMG]
    And glued some more...:roll:
    [​IMG]
    How come I feel the urge to build a small R2D2 ??? :grin:
    [​IMG]
    [​IMG]
    Not perfect but it lookes alright to me...
    [​IMG]
    Last chance to look inside before the cockpit closes :roll:
    [​IMG]
Thread Status:
