Boeing Clipper
Discussion in 'Aircraft & Aviation' started by barry, Mar 2, 2006.
  1. diamondback
    diamondback Member
    Couldn't have been a 314, only twelve were built and all were either sunk or scrapped. I've personally researched the records, hoping one had survived somewhere, but no luck. Maybe a Martin Mars twin-tail?
    Did it look kinda like this?
    http://www.vectorsite.net/avmars.html#m6 (Scroll down 'til you see the photo of Caroline Mars )
  2. diamondback
    diamondback Member
  3. sdk2knbk
    sdk2knbk Guest
    Lots of good photos of the Mars fire bomber in action here; www.pbase.com/jmrickerby/firebig
    If not the Mars, could it have been the Do-24ATT? A surviving Dornier DO-24 was modified with retractable landing gear and three P&W PTA-45B turboprops which replaced the original BMW radials (which confused me when I first saw it locally.) It was originally built in 1944, and served after the war in the Spanish navy, and later as a Dornier testbed. Since 2004, it's been flying for UNICEF, to promote education and awareness for the children of the world, usually with the designer's grandson at the controls! I took some nice shots of it when it was here, and it's on my "some day" design list.
    Scott K.
  4. sdk2knbk
    sdk2knbk Guest
    Scott K.
  5. barry
    barry Active Member
    Flying Boat
    Hi Lizzie
    It's a nice thought I was going to say "as long as it's not too far" but then I remembered that everything is probably far where you live. Unlike me the next area is never more than 10 miles if that.
    At least it brought some interesting candidates for modelling especially that big red Mars fire bomber one day.
    best regards
  6. barry
    barry Active Member
    Flying Boat
    Hi Lizzie
    best regards
  7. barry
    barry Active Member
    what you end up with
    Hi All
    well even the cockpit fitted (even if it should be less angular in profile it will do for me) armed once again with Gil's trick put enough PVA on the edges and the flaps moulded it to shape and put it in the microwave for 20 seconds hadens off a treat.
    [​IMG]
    Thanks Will do you end up with a load of junk like this not including the pile in the dustbin ? Somehow I suspect you are a lot tidier than me looking at your drawings. I kept the battered one to check off new bits for rough size amazing how "improving" something makes a right mess of it.
    [​IMG]
  8. barry
    barry Active Member
    Hi All
    [​IMG]
    [​IMG]
  9. Jim Krauzlis
    Jim Krauzlis Active Member
    Wotcher, bazzer!:)
    I do admire your determination, mate, I really do! Clearly, it does pay off as the latest version has come out so very well.
    Have you updated the files anywhere so we can try to build this latest version?
    You might consider what you have there as junk, but I think it's a gem of a design.
    Never give up, mate, it truly is worth all the effort.
    Cheers!
    Jim
  10. Jim Krauzlis
    Wotcher, bazzer!:)
    Cheers!
    Jim
  11. airbob
    airbob Member
    Boeing 314 build....
    Barry,
    I still have little skeletons of Boeing 707 and KC-135 fuselage sections laying around as you can from this halloween fright shot of my storage desk!!!:-o :-o :-o :shock: :shock: :shock: :p :p :p I's just the price of progress!!! I love the mess!,it's where new things comeChaos!!!:razz:
  12. airbob
    airbob Member
    Barry,
  13. rickstef
    rickstef Guest
    Ohh, The Horror, The Horror.
    Rick
  14. rickstef
    rickstef Guest
    Rick
  15. Willja67
    Willja67 Member
    Me tidy?:rofl: :rofl: :rofl: You have no idea the magnitude of the mess I call a room. My files are similarly disorganized. I have a definate case of A.D.D. (don't tell the FAA they'll yank my license:twisted: ) I get in the middle of something and see someting else that I need to do and start doing that without finishing what I originally started out to do. Hence the mess I made with releasing my corsair too early. I admire your work since I know you've been working on a couple of ships inbetween. Me I took a break for airwolf and a couple tangents on the F-15 and F-18 (got hardly anything done though) and if I get the corsair done by years end it will have been a 2 and a half year project. I think you manage pretty well.
  16. Willja67
    Willja67 Member
  17. shrike
    shrike Guest
    It's not an untidy mess, it's the beginnings of a very detailed diorama of the boneyard down at Davis Monthan AFB<G>
  18. shrike
    shrike Guest
  19. Gil
    Gil Active Member
    Tidyness & Mysticism
    Clean-up usually occurs when I finally can't find anything anymore and ruefully realize that it has to be done. I have a recycled cutoff plastic bottle bottom full of spoked wheel remnants that I call the "wheel barrel". Amazing how much stuff that doesn't turn out photo beautiful but has to remain around to burn in the lesson resulting from yet, another abject failure. This must be rooted in ancient mysticism somewhere as keeping the duds around prevents the evil spirit of the dud from returning once again, abjectly I might say...,
    -Gil
  20. Gil
    Gil Active Member
    -Gil
