Boeing Clipper
Discussion in 'Aircraft & Aviation' started by barry, Mar 2, 2006.
  1. barry
    barry Active Member
    Hi Alcides
    Still thinking about it needs a lot of work scratch building is one thing kits are another science.
    barry
  2. Bowdenja
    Bowdenja Active Member
    Barry it looks great!
    Check your PMs
    john
  3. Amazyah
    Amazyah Senior Member
    Congratulations Barry, on getting model of the week!
    You deserve it, for all your hard work!
    Beautiful craftsmanship!
    Russell
  4. shoki2000
    shoki2000 Active Member
    Congratulations Barry!
    There is something special about those huge flying boats.......
  5. Jim Krauzlis
    Jim Krauzlis Active Member
    Way to go, bazzer!:grin:
    Well deserved picture of the week honor, to be sure!
    Cheers!
    Jim
  6. barry
    barry Active Member
    boeing
    Thanks for the kind words fellas bit taken aback really
    bast regards
    barry
  7. Rick Thomson
    Rick Thomson Member
    Good looking bird Barry. I've alway liked the big flying boats.
  8. barry
    barry Active Member
    Redesign of hull
    Hi All
    Just when you thought it was all over it's back like a bad penny. Having built the TSR2 fairly successfully without all the scaffolding I thought I would try it on the Clipper not that good a build but it does work, and it's a lot quicker to do. The tail end works out pretty good the nose has too many darts cut into it which is ok if you are good at it. The whole thing has 6 formers in it and one butt joint to give the step in the hull.
    The under hull has far to many joins showing so it will have to have a thin paper overlay to clean it up.
    this brings me to my question I have designed this to the actual shape of the nose.
    Would it have been better to straighten the curve enough to produce a less complex fold with no darts in it.?
    second question is it worth bothering to repaint it or is it a bust ?
    [​IMG]
    Thanks Bob for heads up on the butt joint method on the big Jap job.
  9. Jim Krauzlis
    Great work, bazzer! I wouldn't change a thing on the nose, actually, I think it comes out very well using your first design. Keep it as true to the actual plane as you are able, it's worth the effort given the final result.
    Bad penny, indeed...I wish I had a coin purse's worth of such pennies!:)
    I would not drop this project for a moment, so recolor as you see fit. I can't wait for the time to build this one, she's a beautiful bird!
    Cheers!
    Jim
  10. airbob
    airbob Member
    Barry,
    It all looks great to me too!:wink: This project is proceeding in ecxellent fashion:yep:
  11. barry
    barry Active Member
    Repaint revamp
    Hi All
    Decided to repaint it anyway it has the advantage of being simpler to build but I now have the "nasty" butt joint right in the middle of the only long flat piece. Trouble is there are now about 4 ways to build this kite, old nose new back, butt joint the lot (not my favourite) or the original design even I'm getting confused now, correction I've been confused from the start but I think it is somewhere near finished.
    I cheated on this bit lot of cut and rotate I just did not want to recreate that flag.
    [​IMG]
  12. airbob
    airbob Member
    Clipper nose!!!
    Barry,
    Smashing job, mate! This plate looks real professional and cleeeannn!:rofl: :yep: :rofl: :yep:
  13. Ashrunner
    Ashrunner Member
    Barry
    The new texturing looks great. Do you plan to rebuild it again once you're finished with the repaint?
  14. barry
    barry Active Member
    rebuild
    Hi Ash
    Well maybe not all of it I know the parts fit together so probably enough to line up the Stars and Bars and the Transworld sign writing on the mid section ........
    Thanks for the encouragement fellas
    regards
    barry
  15. Gil
    Gil Active Member
    Barry,
    Not to be a nag but Pan American World Airways needs to be side swapped.
    -Gil
  16. barry
    barry Active Member
    Pan Am
    Thanks Gil well spotted !!!
    Trying to cut too many corners again
    regards
    barry
  17. Maurice
    Maurice Member
    Barry
    You haven't got it wrong.
    Gil had exactly the same visualisation problem with the Mig. Caused confusion then as well. :grin:
    Cheers
    Maurice
  18. Bowdenja
    I think Maurice is correct........... IF the white is the bottom and the tear drop is where the sponson/chine thingy attaches and the top is where the wings is attached......... you got it right in the picture barry.
    john
  19. barry
    barry Active Member
    Boeing Nose
    Hi All
    The pics are useless but can't do close ups and this is pure self indulgance. For the first time I have actually got it right. It is all pure butt joints reinforced with masking tape. It takes ages as you can only glue about a 1'4" at a time then you have to leave it to dry for an hour then the next 1/4" .....and at least I know the crazy piece of unfolding produced by Pepakura actually works, but only if it is cut SPOT ON the lines. two more bits to check then I will try and release it.
    [​IMG]
  20. barry
    barry Active Member
    Mods to Clipper bow
    Hi All
    Well I know I released it but I can't help fiddling about the model has irritated me from the start with all the unsightly joins in the forward half of the plane. They would probably look better if I was better at the job and anyway you know what it looks like.
    I had a sudden thought (there's a novelty) that maybe I should go against airplane building convention and split it length wise. To me it seems to be better in appearance at the moment but the join is being hidden by all the construction lines and it will inevitably show up more.
    [​IMG]
    The join line is the 4th horizontal line from the bottom.
    [​IMG]
    [​IMG]
    I suppose I shall now have to repaint the damn thing oh well serves me right for having a thing about this plane.
    Got tto stop after this and number up Norfolk.
    regards
