Blackadder's Imperator Titan Build
Blackadder
660
1,595
91
Weekend Update:
I had hoped to be further along in the rear mechanisms by now but I ran into a bit of a snag when I realized the the rear section of the weapon expanded further than the surface armour surrounding the mount disk. Since my gun is wider overall than the Warlord weapon I have decided to not expand this section unless I see the overall appeal of the Plasma Blaster is compromised.
https://i.imgur.com/opWDHf4.jpg
Another modification is the rear mount must also be removable and be able to slip onto the mount disk assembly which should pose no problem but was something I had not anticipated.
https://i.imgur.com/xFNOLgE.jpg
Now that that is recognized I can proceed with the actual manufacture of the rear sections.
Famous Dave
110
Unfrikkin believable. You are an inspiration to us all. I am absolutely amazed by your talent. Thank you so much for all you share with us.
Dave
Blackadder
660
1,595
91
Thanks for the glowing accolades;
One Week Later:
It's been a busy week but I managed to fit in a bit of building. The biggest accomplishment is a second Arms Mount section for the other armament items.
https://i.imgur.com/9yj9h3H.jpg
It is a source of irritation to me that each of these disc mount appendages seem dedicated to a particular weapon so hopefully I can circumvent this need for redundancy by making a generic disc and adding a discrete weapons module pack for each weapon I produce. The Discs are really time consuming to make.
https://i.imgur.com/6MMTHmi.jpg
https://i.imgur.com/axub5XT.jpg
So above we have the Plasma Blaster modular assembly that slips together as two pieces and subsequently in the image below the sections installed on the Plasma blaster body......
https://i.imgur.com/InJMOrY.jpg
https://i.imgur.com/G4yHwBI.jpg
Next the Meta Snail module...........
9,549
Your consistent plugging away at this is inspirational. You have also taught many techniques, and have shown why build threads are so important! :)
Blackadder
660
1,595
91
You have anticipated my next post; is it any wonder you are the Senior Administrator!!!! :D
Cochlear Implant:
I'm frequently asked how I develop a construction from just images on a computer screen. and I suppose this is a prime demonstration candidate. the Cochlear shaped reactor core at the back end of the Plasma Blaster. Since I already had the disc mount assembly it was a simple matter of transporting the dimensions off the disc to the rectangular grid material and eyeballing the divisions on the screen I used my compass to define where the concentric components would be arranged.
https://i.imgur.com/EWLsQftl.jpg
Using the mount block module I made a U shaped construction of the apparent size of the basic structure and alternately layered 0.040 inch sheet styrene with the same sized grid material until I had a sufficient thickness with two left pieces over for the final rough detail.
https://i.imgur.com/K31AUOk.jpg
https://i.imgur.com/U3NwU5K.jpg
So finally we have the size of the complete weapon realized at least in the rough.
https://i.imgur.com/AzHRLlZ.jpg
and now I can take on the actual upper mount arm............
9,549
I must say I've heard your on this last post!! :sticktongue::smoker:
9,549
This is incredible, just indescribably incredible!!
Blackadder
660
1,595
91
When Will There Be An End?
I am so sick of this weapon. It's like pushing a snowball uphill. The bigger it gets the harder it is to push it further...
https://i.imgur.com/67h9Z7P.jpg
My only consolation is; the rest of the weapons will be a piece of cake in comparison......
https://i.imgur.com/6wvPzCp.jpg
The reactor core is almost complete, I need only add 13 more silver coils and the rest will be eyewash.....
https://i.imgur.com/ZY6Yr3Z.jpg
Last night I built the obverse side and am about ready to install the silver coils on it as well.
9,549
All the work and care shows, it is hard, but it is paying off. These pictures present a hard path for anyone else to follow. You have endeavored much, and much to show for it. ;)
Blackadder
660
1,595
91
Consider Me Crazy:
If someone had told me that it would take me all Summer and then some to make this Annihilator Plasma Blaster I would have considered him crazy.
https://i.imgur.com/huG26nX.jpg
After all I build a Warlord Titan in less than two years and it took about two weeks to make the main Volcano Cannons for that Titan......
https://i.imgur.com/kW0FlHB.jpg
So anyway I've decided to make this weapon modular
https://i.imgur.com/MkkbQDj.jpg
Here we see the four basic components
https://i.imgur.com/4Wla4Tu.jpg
First the mounting disc slides into the main gun housing.......
Then the internal adaptor module for the rear of the Plasma blaster
https://i.imgur.com/zsvdW0Y.jpg
So I can add different parts to convert from one weapon to another easily......
https://i.imgur.com/Y42m4MJ.jpg
The Reactor section then slips onto the internal module.......
https://i.imgur.com/V62R0AE.jpg
This long shot of the business end of this weapon give an appreciation of the scale 30 meters ( 98feet ) length.
https://i.imgur.com/jKUslSu.jpg
And we're back to the assembled weapon... I've got to have my Tech Priests ready next time to have them show of their wares.
Blackadder
660
1,595
91
Cloaca:
At the charging end of the Plasma Blaster is this cylindrical structure that is somewhat convex and fortunately I had a piece of recyclable styrene of adequate size that had a flattened dome shape.
It was a simple matter to divide it into twelfths but somewhat more difficult to space out the segments
https://i.imgur.com/Nq1rhzh.jpg
I want to keep the structure as hollow as possible so I can add balancing weight so once I get the end cap detailed I'll make the rest of the cylinder.
https://i.imgur.com/9T3DiYN.jpg
Everything on this blaster is super detailed so replicating it even as a reasonable facsimile is tedious.
https://i.imgur.com/y5GN5al.jpg
I hope I'll have less trouble with the Volcano Cannons.
To make matters worse my computer crashed last week and I had to reboot window 10
9,549
The coils are a nice touch. This thread should read "Blackadder's Imperial War Monger Titan Build", it has passed "attempts to" a long time ago.
Blackadder
660
1,595
91
A View From A Height:
It's no secret I'm just a copier; none of this stuff is original with me. I prefer to think of myself as viewing from a height; picking and choosing that which I think would go best on my models and adapting the modifications to make them work with the rest of the components. Such is the case with the gun mounts on the Arms yoke I copied from Joazzz2 outstanding 3D masterpiece Emperor Titan. seen below:
https://i.imgur.com/jlKKwDk.jpg
I thought the yoke was a unique way to demonstrate how the upper castle works would need to be shouldered (groan) by the massive gun mount spar
https://i.imgur.com/rRZYHZE.jpg
The problem is that the ForgeWorld Warlord has a much better gun mount then the fork shaped Emperor Titan mount and my problem is adapting the ForgeWorld mount to the Joazzz2 yoke.
Here below we see the Forked mount on the SunFury Annihilator Plasma Blaster and I think you will agree it looks pretty crude compared to the rest of the weapon, clothespins not withstanding.
https://i.imgur.com/3ySlQsY.jpg
Even standing alone the mount leaves me unimpressed.
https://i.imgur.com/DEzWyTH.jpg
Above are the pieces I have thus far made to bring the mount apparatus up to the caliber (groan again) of the FW Plasma Blaster.
We'll see how well this turns out in the coming days.........
Blackadder
660
1,595
91
Reverse Engineering:
Sometimes it pays to be pigheaded such as my obsessive insistence to retain the beautiful shoulder yoke so ably represented in Mr Joazzz2's 3D masterpieces of elegant Emperor Titans.
The other example of my OCD is to attempt to meld that yoke with the equally elegant mounting drums of the Forge World Alpha Warlord.
https://i.imgur.com/VIZTmxK.jpg
Both designs are mutually exclusive as the Forge World shoulders are deeply ensconced under the shoulder carapace and the trunnion mount of Mr Joazzz2's is bulky and somewhat crude compared to the rest of his revolutionary design..
https://i.imgur.com/yyTlbXu.jpg
I am hoping to achieve a middle ground compromise but this first image is a trifle unnerving. The arm seems to be hanging too low and the lower edge of the weapon seems to be at the level of the hip axis.
https://i.imgur.com/CZK70Lx.jpg
Referring to the FW Warlord model and Mr Joazzz's rendering this is also the case but with the body incomplete enough to support the weight of one main weapon I cannot tell for sure.
https://i.imgur.com/DGEu413.jpg
This last image I could not resist posting because it show my inner sanctum replete with plasticard stock which demonstrates the depth of my compulsions. Ha!
https://i.imgur.com/rRRwc6o.jpg
