Battlestar Galactica: Dr Z's antigravity ship
DanBKing
Dan the Man
Feb 29, 2012
1,817
1,587
Netherlands
That little warping was caused by water-based glue; wall1
What glue would you use then, in this sort of build ??
I'm thinking ahead in my current project, and don't want to have warping, because of water based glue, (which I am currently using,) when I attempt the command sphere of the Discovery....:cry:
12,352
Try universal glue from UHU; the main disadvantage is that glue which is not water-based smells which is not very healthy, so when you use it make sure that your working area gets enough fresh air to compensate the effects. In addition, some people (like me :p ) may be allergic to it.
When you use water-based glue make sure that you use it sparingly; apply it gently with a brush instead of making a fat streak out of the tube. I experienced that the amount of water in the glue I am using is rising when the tube is gets empty, so if your glue is too "wet" just switch to a new (full) tube.
12,352
Here are some pics of the flight display stand. I created a mountain base which was heavily influenced by the mountain of "Close Encounters of the Third Kind". The "rock" consists of two parts on one sheet. The texture was made with TheGimp and then projected onto a stylized rock made in SketchUp. I will add a separate page to the package so that you may recolour it according to your needs, i. e. add a brown wash or rotate the colours to get a more deserted or alien look with less green.
12,352
The model rests on a dish which is textured like the circle on the bottom of the ship. So it looks as if it is balancing only on a tiny black pole in the middle, giving the impression to be floating. I'll try to find an acrylic rod to increase the effect.
9,892
FANTASTIC MODEL!!!
Yes, G-80 was a crap show, but you did an AMAZING job on this model.
KUDOS to you for another job well done.
For the stand, you could use sheets of clear plastic (like from some of the clear plastic IKEA packaging) and roll it into what ever size of tube you need.
12,352
Thanks for the tip, RB! I'll give it a try as soon as I can find some.
Here are some pics of the ship's landing struts. You can build it with or without them.
12,352
I chose to build my prototype without them. The landing strut housings are closed in this case. The second picture shows a nice bottom view of the model with all greeblies in place.
12,352
And here it is, Dr Z's antigrav ship. Despite my initial worries the final model has indeed a fine size, I don't find it too big any more. If you look closely you'll see that I was able to "beat out" the warping a bit by cutting into the outer edge of the warped parts and taping the two ends together so that they overlap a bit. An easy and effective solution. I even had some time for a little Gimp magic (last pic). I'm certain that a version equipped with LEDs would become an even more impressive display piece. :thumb:
This is the 25th model I have designed. As I said before I made this model for one reason only, to learn how to apply a texture to an uneven surface in SketchUp. Even though there is a little error I was unable to fix I must say that the result pleases me very much. It was a fun project which taught me a great deal of handling textures. One of the main disadvantages of SketchUp and Pepakura is that they do not accept texture maps above 1024x1024 pixels. I worked around that limitation and rose texture and export quality by not using one single map but four individual maps with max resolution each. The result is much crisper and cleaner. BTW, the procedures I learned here will be essential for the next project by me and Rhaven (yes, we are teaming up again!). I've sent the kit to him for approval and asked him to add it to the BSG downloads section. Till then, enjoy the pics! :wave:
clif52
Banned
Oct 23, 2004
129
4
Martinsville, Virginia USA
Very COOL! Neat looking saucer design. Is it just me or looking down on it does it remind you of the mother ship from "V"? I wonder with a little redesign and a change of textures could you create the "V" ship?
Ciif
12,352
Ciif
I knew someone would ask for that! :twisted:
As you might know, I am making the V blaster. One of the first design ideas for the stand was to create a little mothership as a base. I have begun modeling a simplified version of it, but then noticed that the base would become larger than the blaster which wouldn't be good (it should be a model of the blaster and not of the mothership with a blaster on top). The studio model was very small, even smaller than the fighters and transport ships of the Visitors. I still have my original SketchUp file and surely could rework certain areas to get a nice mothership papercraft. Interested??? :rolleyes:
9,892
There is an updated and corrected file of the original kit to Dr. Z's ship in the download section.
If you have already downloaded the old one, please note that the last part on the last page is a former and should be marked F1, as this kit shows.
Sorry for any confusion that this has caused.
ENJOY!!!
12,352
Hello folks!
You might wonder what caused me to get back to a project which was completed two years ago. Well, I'll tell you. When I designed this model I only had two tiny blurry pictures of the top and bottom of the studio model and some screenshots from the series to work with. A few months ago new pictures popped up at www.byyourcommand.net . They revealed that the top of the saucer / the bulge was much higher than anticipated. That made me revise the kit. This also gave me the chance to change the way of assembly to make the build easier (I hope). Now it basically consists of three hull pieces which are stacked on top of each other (instead of one huge hull piece which could cause some trouble when the top part is attached):
Each segment features its own set of formers.
I'll keep you posted. ;)
Reactions: zathros and bgt01
9,549
Does it go further when you throw it? :Coffee:
clif52
Banned
Oct 23, 2004
129
4
This model is too COOOOOL! Have you thought about making an angled cylinder with the bottom wider than the top out of recycled clear blister pack instead of the rod. It would look like a force beam holding the ship up. You could paint it with clear model car paint or use clear sticker material and print it on the ink jet. Now I need to build two, one for my Galactica collection and one to light up and hang over the X-Files action figure display base I'm working on. Mulder & Skully standing in front of the Area 51 fence and the Alien standing behind the fence and them.
12,352
That's an excellent idea! :) I'm looking forward to seeing your results (especially the base / diorama).
Black was my colour of choice because you always saw the ship at night and a black rod would fit in that scheme. Of course you may do whatever you want to improve the kit. RB is doing a test of the new shapes soon. You may practise with the previous version which is still available in the Resource section or at www.stevespaper.com . ;)
