Battlestar Berzerk
Discussion in 'Science Fiction & Fantasy' started by dirkpitt289, Nov 17, 2018.
  1. dirkpitt289
    dirkpitt289 New Member
    My favorite ship from the Battlestar Galatica series(s) was the barely seen Battlestar Berzerk. The Berzerk (From Old Norse berserkr (n.) "raging warrior of superhuman strength." ) was a support ship much like today's destroyers, designed to protect the Carriers, they prospected the Battlestars. The Berzerk was seen for only a few seconds docked next to the Pegasus at the Scorpion Fleet Shipyards when the Cylons struck as part of their attack on the Colonies.
    I thought I posted this build when I first joined the forum last year but I guess I was wrong. I originally build this about 4 years ago. I will be posting the video series on my Youtube channel sometime soon. I hope you like it
    The kit comes on 4 sheets and builds up to about 16 inches in length IMG_20140919_204409_020.jpg
  2. dirkpitt289
    I started with the engines, 4 in total IMG_20140919_222811_555.jpg IMG_20140919_231225_036.jpg
  3. dirkpitt289
    The Berzerk, Unlike Battlestars we've seen in the past has just one small landing bay and its tucked under the belly of the ship.
    The Flight deck
    The roof of the flight deck
  4. Revell-Fan
    Revell-Fan Co-Administrator Administrator Moderator
    dirkpitt289 and Rhaven Blaack like this.
  5. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
    It looks like you are off to a great start. I will be following this thread.
    dirkpitt289 likes this.
  6. dirkpitt289
    Building the gun platforms
    The initial folds
    Final shape (Yawn... Boring)
  7. zathros
    zathros -----SENIOR---- Administrator Moderator
    Eventuallu, you will stop using tabs, and use 90 degree folded pieces of paper. that allows you to do one edge at a time, you fit one side, let the glue dry, and then when you glue the next side, it will be lined up perfectly, without the gap from that tab. :)
    lyter1958 likes this.
  8. dirkpitt289
    Someday.... Maybe once I get the hang of doing these first thumbsup
  9. zathros
    It's actually an easier way to build a model. The pictures below I made show why and how. I thinks the pictures are self explanatory. ;)
    [​IMG] [​IMG]
    Sky Seeker and dirkpitt289 like this.
  10. Gandolf50
    Gandolf50 Researcher of obscure between war vehicles... Moderator
    Just think..you won't have to cut around all those fraking tabs!!;);)
    dirkpitt289, lyter1958 and Sky Seeker like this.
  11. Sky Seeker
    Sky Seeker Well Established Member
    That's true, but I've found some models work well with the tabs. For example, the head for the Vorchan. I don't think that I could have built it without tabs. Maybe I should try building a sample model one with tabs and one without just to see the difference.
    Sky Seeker
    :tank:
  12. Sky Seeker
  13. zathros
    Cutting off tabs always works better, unless you try to do it all in one step, then you a creating a mess. You first glue the locating tab on one surface, using a piece of paper the proper size to push the tab back the proper amount, which is how you locate the separate tab or fold tab (above left picture), you do the same thing on the other side after the fist day has dried. When both sides have dried, you will find that the last parts will fit in perfectly, if you located you separate tabs right, and just glue it in. The corner whipp be sharp and you will see glue gaps in the edges. I see these gaps and wonder if people just are in denial, or just don't get it. Those gaps will kill the best of models, and I have seen some by really good builders and though, if it wasn't for that one gaping gap, the model would be perfect. I guess it could be posed that way, to hide the defect.
    Cybergrinder likes this.
  14. dirkpitt289
    Its been some time but i'm back at the Berzerk. Here is the building of the spine of the ship
    The Engine mout for the 4 engines
  15. zathros
    These very clean, straight and true parts show the foundation of a great model. ;)
  16. dirkpitt289
    Thank you
    zathros likes this.
  17. dirkpitt289
    I started work on the massive head of the Battlestar. Everyone keeps saying to get rid of the attaching tabs. After my first attempt at this part I get it now. For my second try I decided to remove the tabs for a much better result.
    IMG_20140921_231655_956.jpg IMG_20140921_233225_974.jpg IMG_20140921_233928_485.jpg IMG_20140921_234946_882.jpg IMG_20140923_225701_172.jpg
  18. Revell-Fan
    I did the same on my Berzerk. It gives a much cleaner and smoother result. Make sure you are pre-shaping the parts carefully. Roll them over a pencil or a rod where the hull bends into a curve. Crease it on sharp edges to make them sharp. You may use left-over / scrap paper to make small tabs and glue them to the back of the hull. So far everything looks great! :)
    lyter1958, Gandolf50 and dirkpitt289 like this.
  19. zathros
    If the parts fit tight when dry, they will fit even better with glue on them. ;)
    lyter1958 and Revell-Fan like this.
  20. dirkpitt289
    That big ole head is coming together
    IMG_20140923_225706_070.jpg IMG_20140923_225712_990.jpg IMG_20140923_232415_650.jpg IMG_20140923_232422_145.jpg
