Back Burner
Discussion in 'General Card Modeling' started by silverw, Jul 6, 2004.
  1. Maurice
    Maurice Member
    Bill
    Congratulations on thinking of sloppy bushings, very ingenious.
    This is paper engineering rather than just paper modelling.
    I do hope the mood takes you to do more.
    Cheers
    Maurice
  2. Medic
    Medic New Member
    wow. that's incredible. maybe you have some tips for us relative paper model novices :p
  3. silverw
    silverw Member
    Well, thankyou...guys...I guess I'm going to have to drag this forward..and crank up the heat!!
    Hhmmmm......Paper Engineering...that has a nice "ring" to it!!
    I guess I should explain that spring....which will keep tension on the tracks...(there is a ball point pen spring conceiled in there!!) You have to look close at the photos...........
    Then there is the paper threaded rod...and nut to fit...so that you can adjust that tension................
    BCNU.............Bill
