B-737
Discussion in 'Aircraft & Aviation' started by Cybermac, Aug 7, 2007.
  1. exzealot
    exzealot Member
    Hi Cybermac,
    It's only weak BEFORE it is permanently glued. Without understanding the whole picture, my first suggestion would be: leave it as it is currently designed UNLESS is it weak after it is glued in place.
    Ken
  2. Cybermac
    Cybermac Member
    Thank You guys! I am just about to do it!
  3. Bowdenja
    Bowdenja Active Member
    Superglue....... makes plastic out of paper........... whoops....... I said the "P" wordhamr
  4. Cybermac
    Cybermac Member
    Here it comes...
    ('Life in plastic is fantastic' - only for Barbie Girl:mrgreen:)
    As you suggested I've put a second layer of cardboart on 2 sides of pylon to make it stronger, and it really works!!!:thumb:
    Cybermac
      File size:
      19.6 KB
      25
      File size:
      21.8 KB
      22
      File size:
      20.4 KB
      24
  5. exzealot
    exzealot Member
    Cybermac,
    After seeing the part in its final position, I believe this may have been strong enough without the cardboard. It is a box section (3 sides), with the top face of the box glued to the top of the wing. The back of the engine rests up against the back of the part preventing the assembly from drooping down in the front.
    Just my opinion, but nothing wrong with reinforcing for a margin of safety either.
    Ken
  6. Cybermac
    Cybermac Member
    Fuselage
    OK, thank You guys!:thumb:
    Now little bite more details on the fuselage...
    Cybermac
      File size:
      21.3 KB
      22
  7. Cybermac
    Cybermac Member
    B-737-800 from Turkey...
    Hello!
    Looking through the net I found nice B-737-800 cardboard model!
    http://www.ihmpmuk.com/07_galeri/ercument_sarikaya/02_B737.htm
    Maybe there are some usefull informations how this beauty was build, but everything is only in Turkish...
    Anybody of You guys speeks/understands Turkish and can tell something about that?:twisted:
    Cybermac
  8. Cybermac
    Cybermac Member
    Step by step
    Hi all!
    The first Boeing's 'nose' and cabin were too long when I compared with more advanced drawing, so I am making new one...
    Sayonara Pinocchio:wave:
    Cybermac
  9. knife
    knife Member
    Glad to see that you are still at it. I was modifying my 737 (AirTran and Southwest Airlines) to model COPA Airlines using photos for the texture, like I did for the cockpit windows. Gave up a few months ago when I couldn't get the printer to print the same hues between sheets. I did get the wings and winglets to come out pretty good.
  10. Cybermac
    Cybermac Member
    nose cone is coming...
    Hello!:wave:
    To make this nose cone precisely, I made designing parts 2x bigger.
    Later on, of course I'll put them into the proper 1:72 size, just like on the picture...
    Cybermac
  11. Cybermac
    Cybermac Member
    Cabin...
    Hello!
    Now I am trying to make cabin...
    Cybermac
  12. Lex
    Lex Dollmaker
    Nice! How much detail are you prepared to sqweeze into there?
  13. Cybermac
    Cybermac Member
    Details...
    Hello!
    If it was not a B-737 but for example Su-27 or F-15 which scale drawings You can find anywhere I would be able to do anything...
    After a long internet battle I bought an old issue of Aviation News recently (the bottom one) which proudly says 'BOEING 737 SCALE PLANS' but only a side wiev is 1:72, cross sections aren't done properly...
    I hope I will not disappoint You, but so far I can do only some basic details like doors, cargo doors, windows etc. I am going to add some more according to painting scheme later on.
    Cybermac
  14. knife
    knife Member
    I will try to send you my cabin area via PM. It doesn't have interior shots, but uses photos for the windows. I found the most difficult area to get looking right is the fuselage immediately behind the cockpit, the part uncovered in your photo.
  15. Cybermac
    Cybermac Member
    Any help will be appreciated!:thumb:
    So far my 'details' are looking like this...
    Cybermac
  16. sdk2knbk
    sdk2knbk Guest
  17. Cybermac
    Cybermac Member
    Does it fit?...
    Hello!
    Now I am trying to fit a couple of segments...
    After a long time of drawing, cutting, copying...
    Let's see it in real...:mrgreen:
    Cybermac
  18. Cybermac
    Cybermac Member
    Hi!
    Couple of days later... cabine is done! UFFF
    Cybermac:wave:
  19. Cybermac
    Cybermac Member
    and now from the tail side...
    Hello!
    I didn't wanted 'to copy' the tail end from Geli model so I've done it my way...
    Cybermac:wave:
  20. philipme109
    philipme109 New Member
    You Sir!
    Are doing a fantastic job!! I hope you would consider doing other airlines.
    Keep up the GOOD WORK!
    Phil
