b-17 gpm step by step
Discussion in 'Aircraft & Aviation' started by yaniv, Dec 1, 2006.
  1. yaniv
    yaniv Active Member
    rhan i start glue the parts
    useing super glue
  2. yaniv
    yaniv Active Member
    finsh tham
    left and right seats
  3. Bowdenja
    Bowdenja Active Member
    Yaniv,
    Since you now have a very wonderful panel, why not take the time and cut out the belts and seat pad and make them 3D to match.
    This is going to be a great model and I'm glad you got brave enough to start............. I'm not so brave:grin:
    It's looking good!
    john
  4. yaniv
    yaniv Active Member
    jhon u sat
    u can sow me some pic how to do it?
  5. cmdrted
    cmdrted Active Member
    You could cut out some strips of newspaper and paint them olive drab, and then add cut out buckles to place on the ends, the seat cushion can be cut out card, painted in a leather or other cushion type color. The belts should be "wrinkled" a bit to give them a little sag. Or print out the page below in A4 .
  6. Stev0
    Stev0 Active Member
    Whoops... someone beat me to the punch.
    Yes you could print out that sheet and carefull add the pieces to draw out more detail.
  7. yaniv
    yaniv Active Member
    thanks alot ppl i going to tray it :)
  8. yaniv
    yaniv Active Member
    thats the one i have
    wow i am so need to found the guts for it
  9. yaniv
    yaniv Active Member
    what we have so far...
  10. yaniv
    yaniv Active Member
    thats what we have for now
    the 75% of the cockpit
    i not like mach the reasolt its not like we use to see on the halinski models
    and the news gpm and some meny more
    its just out of diteling :(
  11. yaniv
    yaniv Active Member
    1 more
  12. cgutzmer
    cgutzmer Guest
    That is one GREEEEEEN cockpit :) must be a night flight ;) heh heh looking good so far! Thanks for sharing.
    Chris
  13. yaniv
    yaniv Active Member
    thanks for the good word my friend
    but the cockpit parts not that fix good and thats way i not like him
    hope in the end to gave him mach more life :)
  14. RichBohlman
    RichBohlman Railroad Card Modaler
    Nice Looking Build!
  15. yaniv
    yaniv Active Member
    WOW that part whas realy hard to make...
  16. yaniv
    yaniv Active Member
    pic 2
  17. yaniv
    yaniv Active Member
    pic 3
  18. cgutzmer
    cgutzmer Guest
    gonna put in some glass? :D looks good!
    Chris
  19. yaniv
    yaniv Active Member
    yes on the glass i will work tommarow
    i plan to print the some part i have from scenning this part and make it over regular a4 paper
    than conect the glass on the outside of the part and than conect all under the original part
    so the all part will be like a sendwich
    mybe i will tray also make ather 1 and glue its all with super glue than to shaff and paint it with silver color all over and gave it a look of plastic part
  20. cmdrted
    As do I! Looks good for now, best of luck with the glass!
